Old 24th October 2021, 09:08 PM
Default Tyre sizes for 9" 20s?
I'm considering putting my (spare...) set of 20 rims - which are 9" rather than the "proper" 8.5" ones - on my S8 as winter wheels this year.
Am I right in thinking that these 9" rims would take the same size tyres as the 8.5" ones, which this page suggests, I think?:
http://www.audipages.com/upgrades/tiresizeoptions.html
Old 24th October 2021, 09:11 PM
Markiii Markiii is offline
0.5" yeah same size should be fine
Old 24th October 2021, 09:33 PM
Yeah 255/35-20 will be fine on 9s - that's what I'm running
Old 24th October 2021, 09:42 PM
Grand, thanks
Old 22nd November 2021, 09:15 AM
Default Additional winter wheels/centre caps question...
I have a set of centre caps - suitably darkened to match the winter rims - from a "spare" set I had lying around - but they seem to be a very tight fit, and I'm concerned about them not fitting, or the lugs breaking if forced
Is this a sign that they're cheap Chinese ones (quite possibly why they were lying around ), and is there a knack to persuading them to fit snugly?
Old 22nd November 2021, 09:39 AM
Yes
In this weather I'd put them on a radiator for a couple of hours to warm them up, then WD40 on the tabs and some percussive maintenance! Make sure the locating lug on the wheel is lined up with the slot on the outer edge of the cap. Hold that in place and then a solid whack on the centre of it should get it to drop in place.
Good luck getting the buggers out again though
Old 22nd November 2021, 01:23 PM
Yes and not really. I'm sure I posted somewhere (here ages ago) about how to tell the difference and one way to make them fit better, but there's no "knack", just brute force unless you "customise" them....
IIRC the lugs are a different, more rigid, shape and the spring rings are stronger too vs OEM. I think I got some of my cheap Chinese ones to fit by using much weaker rings from a completely different set (non-Audi) of spare/redundant wheel caps.
You might also want to look at the lugs and consider carefully paring some material off to make them more like OEM.
Edit: See this from 2017: http://forum.a8parts.co.uk/showthread.php?t=13223
