Go Back   A8 Parts Forum > A8 D4 > D4 - Common Faults
D4 - Common Faults Quick links to all known common faults and their solutions
Old 21st May 2016, 06:14 PM
Joe2.0E Joe2.0E is offline
Thanks for posting, I'll add it to my to do list.
Would it be possible to access by removing a wheel arch liner ?
Old 22nd May 2016, 10:34 PM
nath nath is offline
yes for the front plug
however here is one which is sandwiched between the inter-cooler
and the pump itself
this is difficult with the **** guard off
i would say even more so with just the wheel arch removed
Old 22nd June 2016, 08:48 PM
damtom85 damtom85 is offline
hi all
are you all talking about this issue because my a8 is having this error since i bought it
Code:
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 4H0 820 043 G    HW: 4H0 820 043 G
   Component: Klima 2 Zonen H20 0110
   Coding: 3621002830
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_AU64.rod
   VCID: 2447AAB92FD469012A7-8071
1 Fault Found:
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 79318 km
                    Date: 2015.03.27
                    Time: 08:02:51
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a
Old 22nd June 2016, 09:00 PM
Mine has had a new pump fitted - under warranty so no idea of cost but don't think it was a huge job.
Old 22nd June 2016, 09:06 PM
but photos that Nath added, are they regarding my fault with cooling pump ?
Old 23rd June 2016, 05:35 PM
Originally Posted by Joe2.0E View Post
V059121012A is the part no. for the coolant pump replaced on my D4.
Google indicates its a small cheap looking plastic pump, no surprise it didnt last long. Not sure it does much anyway as i hadnt noticed any issue prior to replacement or any difference afterwards.
Photo attached from Garage Paperwork. Prices are in € + vat.
i cant find this part as this is the pump is likely to throw fault
Old 23rd June 2016, 06:22 PM
according to another thread on different vw/audi forum coolant pump V50 is located in firewall. so basically i need to remove plastic covers next to windscreen and i should see it
Old 3rd July 2016, 08:18 PM
ok let me sum up,
my engine is 3.0 tdi. according to audi in my car is only one valve- n509 doesn't exist in 3.0tdi, only n488 and has number 4H0121671D and looks like that:
https://flic.kr/p/HPEtKN
and in my case this valve is located next to gearbox, between gearbox and geabox heat exchanger (small radiator)
also circulation pump v50 has number 059121012A and looks like that https://flic.kr/p/JKX8Va
and it is located in firewall on left side if you look from front of the car
https://flic.kr/p/JKWJdF
https://flic.kr/p/JKWJbr
https://flic.kr/p/Jkam8C
and this error / fault
Code:
   Coding: 3621002830
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 79318 km
                    Date: 2015.03.27
                    Time: 08:02:51
it is caused by this pump, and needs to be replaced for error to be gone.
thanks
Old 11th November 2016, 10:12 PM
Albert_Swafega Albert_Swafega is offline
damtom85,
i see it was summer when you changed your pump, don't suppose you noticed if the blowers got warm?
mine are all but stone cold, only just noticed as the weather has turned, and the only error thrown is the same pump error as yours.
makes sence, i think, but don't want to waste £100 on a pump if it's not the fault
cheers
Albert
2011 A8 Executive 3.0 TDI Quattro
Old 11th November 2016, 11:45 PM
Hi.
car gets warmer much much quicker than before, I bought used one for £40. audi fits them in A8, A7, A6, A5, A4 so it is easy to find them.
PS. I changed mine 2 weeks ago not in summer. I knew what was the issue but didn't have time to do it. however now weather turned cold I needed to change it. Done it in 20 minutes, difference is huge.
