Old 27th October 2015, 11:04 PM
laketahoequattro laketahoequattro is offline
Ok did some diag. Opened the lower heater hose vent and some air bubble mixture came out. Not a lot, but bled it until it was just liquid.
Next I checked with thermocouple probe. Temperatures match what vag com are saying, so it is not sensor.
Then I decided to touch lower radiator hose. Stone cold. So this means thermostat or water pump? Both are brand new, I highly doubt it is water pump. If either of these failed I would expect some massive over heating issues.
Is there any better way to burp the radiator or coolant system in this car? I feel like a huge air bubble is between the thermostat and radiator even tho this does not make sense either
Edit: Heat is fine. Not as hot as I would expect, but it does blow hot air. Both heater hoses are hot.
2003 A8L Build Thread
D3 Turbine Reps – S8 Mani
2002 Allroad Build Thread
2005 Color Match - TDI 01E - TTV LWFW - RS4 PP - BW K04s - Stg 2 WMI - WB- AWE DTS - EFK - H-SPORTS - IPP Arms - S6 Alcantaras - 4K LB Hitch - V1
Old 27th October 2015, 11:20 PM
sounds like the stats not opening at the correct temp
Old 27th October 2015, 11:42 PM
Do you know of anyway to check the temp in vcds of thermo fan switch?
Yea I am starting to think t-stat as well ugh
Old 27th October 2015, 11:47 PM
Sorry don't think thats available in vcds, might have the specs in the manuals though.
Have you had a look at the manuals here
http://forum.a8parts.co.uk/showthread.php?t=9345
Old 7th November 2015, 07:24 PM
I tested the old thermostat and it opened at the correct temperature. Now I am really at a loss. There was also coolant in the thermostat housing and lower heater hose. I'll try flushing the radiator again, then I'll be stumped.
Old 7th November 2015, 07:59 PM
What's shown on the dashboard?
The reason I ask is I was sat in the car for a while the other day while building a label file for my engine, I noticed that my car also sat at a solid 105 on VCDS but shows a steady 90 on the dash so it may be designed into the car
Old 7th November 2015, 10:08 PM
It is an 03 so it does not have numbers on the coolant gauge, but it moves from the "middle thick" line to the next tick over to be at more 12 oclock or 12:30. The deadzone on my instrument cluster is 80-100 degC, after 100 the needle moves up. When you are on the freeway or accelerating, what does your vcds say?
I also replaced the coolant temp sensor and I also ran a hose thru the radiator and it did not appear to be clogged. The lower radiator pipe is still cold while top pipe is super hot which makes 0 sense to me. While accelerating I get 107degC, at idle I am at 100degC.
Old 7th November 2015, 10:28 PM
I was gettin 105 to 107on VCDS at idle but the temp gauge stayed steady at 90, when I go out in the car next I will log the engine temps
Old 10th November 2015, 02:35 AM
I'm starting to lean towards a clogged radiator.
Old 10th November 2015, 09:03 AM
It would need to be seriously clogged to stop all flow from engine, it will be quite easy to check but you say you done already, when was the water pump last replaced?
Tags
coolant, high coolant temp, thermostat
