Old 5th December 2018, 09:53 AM
Markiii Markiii is offline
Default seperate instrument cluster
Hi chaps
getting the cluster out is is fairly straightforward. Separating the clocks from the front cover is easy enough
However I want so separate the front perspex from the black piece with the gauge holes in it.
Its not obvious and I don't want to risk breaking it.
Any tips?
Old 5th December 2018, 10:27 AM
If I remember correctly it's just screws and snapped together.
Old 5th December 2018, 10:51 AM
RICKY D's Avatar
RICKY D RICKY D is offline
I think this Audi pages post shows where you how to do.
http://www.audipages.com/upgrades/dashrings.html
2016 S5 Coupe Black Edition - Ibis White
Old 5th December 2018, 11:29 AM
thanks but alas not it shows the rings attached from the back whilst leaving the perspex cover over the apetures in place
Old 5th December 2018, 11:34 AM
I'm pretty sure the clear face is plastic welded to the black surround and does not come apart. I've not looked closely at this in the D2 but all the other contemporary models are done like that.
The rings push through the holes from the back though. Why do you need to take the front apart?
Old 5th December 2018, 12:21 PM
you know how CSI show superglue in a sealed bag showing up fingerprints well it seems the cluster is sealed sufficiently to achieve the same thing
I now have a misty inside of the perspex that was not there when i put it back together
not to mention squeezing the chrome rings through a gap smaller than them has left them bent out of circular
Old 5th December 2018, 12:28 PM
Oooh that's annoying I think you'll need to clean it from the inside though. I can have a look at a cluster later to confirm it is welded or not.
Old 5th December 2018, 01:27 PM
thanks, yes I was not happy when i got in this morning
Old 16th December 2018, 03:55 PM
the misting effect from the glue seems to be getting ever worse. I have a feeling I'm going to need a new cover
anyone have one for sale? don't need the hole cluster just the front perspex part
Old 17th December 2018, 10:40 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
I've the remains of a cluster in the garage - let me see if the front perspex is presentable
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
