Old 1st October 2017, 08:01 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Audi plugs
Does anyone know of a good web site that has a good selection of Audi plugs?
Audi don't do the plugs that I need.
[center]
06 3.0TDI Quattro:
Options:
Old 2nd October 2017, 07:27 AM
peiiider peiiider is offline
If Audi doesn’t deliver the plugs, that means you don’t have the part number ?
I have seen that ecstuning have a big selection of oem electric bits, probably other similar shops too, but it might be difficult searching for it without a part number..
Or if you try to google what it’s used for: «audi windscreen washer plug» or something ?
06 A8 3,0TDIq My daily driver and project...
97 A4 1,8Tq. Powered by a 4,2 from the '01 S6, full rollcage, FIA seats and 6-point harnesses, B5 RS4 KW Competition race suspension, B6 S4 brakes, 18" Toyo RS1 slicks, carbon fiber roof. V8 trackday racer
14 VW Caddy 1,6TDI from my employer..
(X)00 A8 2,8q, (X)97 A4 1,8Tq, (X)92 S4 2,2Tq, (X)92 80 2,3E
Old 2nd October 2017, 09:18 PM
Somerandomguy's Avatar
Default Helpful doc
Some time ago I came across this useful document which lists many common connectors and pins
http://www.vaglinks.com/Docs/Catalog...m_Audipins.pdf
I also use ETKA to find the connectors if its not in the above as each loom has a diagram and parts list
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 3rd October 2017, 09:45 AM
ScottD3's Avatar
I've gone through ETKA.
That's a nice little PDF. Thank you.
I need to make an adaptor cable to convert my car from 26 pin to 20 pin.
I need the 26 pin socket so I can plug my OEM 26pin plug in to it.
I don't want to remove the plug and put the 20 pin one on in case I got to revert back to 26pin.
[center]
06 3.0TDI Quattro:
Options:
Old 3rd October 2017, 11:28 AM
20 pin CAN plug, 8E0972420B. Probably cheaper through TPS.
www.ebay.co.uk/itm/282521513257?
But this used one is better as you'll get the pins and some wire.
http://www.ebay.co.uk/itm/263221449575?
Edit
I actually have a few of these myself. I could probably make the 26>20 adapter as I have all the parts and pin outs.
Matt
Old 3rd October 2017, 04:31 PM
ScottD3's Avatar
I got a 20pin plug from a FIS cable I got left over, its the 26 pin socket I need so it all clips together OEM style and doesn't fall apart.
I'll PM you.
[center]
06 3.0TDI Quattro:
Options:
Old 28th October 2017, 11:58 PM
neeldub neeldub is offline
Hey try http://www.automotive-connectors.com/
they are very good at responding to queries and ship very quickly too..
They have a comprehensive list of all VAG plugs, terminals and seals etc
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 3rd November 2017, 05:48 AM
ScottD3's Avatar
Thanks for the advice all.
I ended up stripping an old gateway I had and it works a treat.
[center]
06 3.0TDI Quattro:
Options:
