Old 21st January 2018, 05:45 PM
triumph2.5pi triumph2.5pi is offline
Default Modern DAB replacement
Hi all. Could anyone please advise if there is a modern DAB unit that could be fitted to my facelift D2 with a reasonable amount of work ie it not costing an arm and a leg? I'm a complete layman so would need to pay an auto electrician to install.
I would mainly like DAB and iphone connectivity.
I'm thinking a unit something along the lines of this:
http://www.kenwood-electronics.co.uk...b/DPX-7100DAB/
Is something like this possible without a silly payout to fit? Or am I barking up the wrong tree? Any help or advice greatly appreciated! :-)
Old 21st January 2018, 06:50 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Are there any Android head units available for the D2? That’s where I’d be looking for added functionality. Would also be plug and play, you’d hope....
2007 Mini Cooper S R56
Old 21st January 2018, 08:43 PM
I can definitely recommend the Kenwoods and their JVC equivalents. We have them in all our cars. Looks like you have a single-din dash so simplest to go for one of the single din Kenwoods too. I'm not sure if you can get a facia plate for the single-din D2 dash - you can't for the double-din so it has to be fabricated. There is a standard din-size hole back there but in the double-din its recessed a bit so it might still be a bit of a challenge to get it right.
Electrically it is relatively straightforward - you can get adapters from Autoleads to hook up to the original cabling (including Bose). You'll lose the FM antenna since the switching unit needs a signal from the original head unit to power up, but if you're going for a DAB head unit hopefully that won't matter.
Old 22nd January 2018, 05:27 AM
Thanks very much!
There appears to be a single din facia plate for a D2 here:
http://www.caraudiodirect.co.uk/ctka...stallation-kit
Old 22nd January 2018, 08:55 AM
I have 1 of these fitted to the OEM radio on our C5 A6 https://www.amazon.co.uk/Genuine-Hyu...+highway+300di
Old 23rd January 2018, 07:00 PM
I'm having a Kenwood KDC-BT720DAB supplied and fitted on Thursday for £185 + VAT :-) Will post a pic!
