Go Back   A8 Parts Forum > General Natter > House and Home DIY
House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes
Old 2nd April 2018, 07:55 AM
Default Home Automation - Heating and Hot Water
I'm after recommendations.
I currently have the central heating fitted with the EQ3 Max system. Each radiator on a WiFi TRV, primary rooms have a thermostat and many doors and windows have open window detectors. All runs from an app on my phone allowing me multiple configurations (just us, 1, 2, 3 guest rooms in use etc.). What it doesn't have is a link with the boiler to switch on and off dependant on demand.
Any recommendations on a system that will control the boiler and hot water as well. It must be Alexa compatible as well. I will be selling my EQ3 Max stuff this summer and fitting the new system.
TIA.
CtL
Old 2nd April 2018, 08:17 AM
Honeywell is doing a system with radio controlled TRVs that are managed from central console or smartphone. Additional room thermostats can also be added. Central console will switch on boiler when required. No idea about Alexia though.
But IMHO Nest is the best. It has ho radio control TRVs though, but this is not needed if you have manual TRVs that you can configure and forget about. I have 3 zones in the house plus hot water. 3 Nest thermostats control 3 zone valves on s-plan system plus hot water zone valve. Each zone has its own schedule. Wired installation, but wireless is also possible. Installed everything myself. Excellent app.
Old 2nd April 2018, 10:16 AM
I think nest were also doing an offer where they gave you a free Amazon Echo Dot recently through British Gas, so Nest must be Alexa compatible
Old 3rd April 2018, 02:24 PM
Currently looking at the Honeywell system. Thoughts?
Old 3rd April 2018, 06:54 PM
Honeywell is making great stuff
Old 6th April 2018, 09:46 PM
I run a nuheat thermal store, which works brilliantly, albeit a departure from typical domestic installs.
It basically a giant hot water cyclinder, but full of central heating water.
Boiler runs on a standard thermostat to keep it topped up to temp as required. Also has inputs for green technologies, solar panels etc.
Then, your heating just draws off the hot water as required via the normal CH pumps.
HW is mains pressure, but heated on demand via coils inside the thermalstore, giving instant, endless hot water.
Much more efficient for dribbling out bits of heat here and there as the boiler only need kick in occasionally to blast things back up to temp. Designed with underfloor heating in mind, but equally useful for rads.
I bought mine second hand, installed it about 6/7 years ago now and its been great.
