Old 13th November 2017, 08:43 AM
Alex C Alex C is offline
Default First problem! Door handle
Hi all
As the temp have dropped, it seems my drivers door refuses to open from the outside.
The keyless system was a little odd in behaviour thinking back, in that I often had to actually pull the handle a little before recognition, whereas the other doors work with just proximity or the lightest of touches.
Now its just dead until the car has been driven a while, then it seems to work OK. I haven't yet checked for codes but will tonight or tomorrow.
I am likely stuck with stripping the door down and fitting a new handle or can copious contact cleaner / WD40 fix w temperamental one?
And where is the best source for one?
Thanks.
Old 13th November 2017, 04:19 PM
It may be that the colder weather is highlighting a poor battery.
I am aware that some of the electrical ‘luxury’ features (auto boot, softclose etc) are the first to be restricted to preserve battery energy when the battery is dying, often discovered at first unlock in the morning, especially after a couple of days of inactivity.
Also I believe that locking/unlocking via the key rather than the door handles prevents additional drain if you have an existing faulty handle(s).
Doesn’t completely solve the door handle issue but a frequent squirt of GT-85 does sometimes help, in the short term.
Old 13th November 2017, 04:34 PM
Thanks
Its only the drivers door and it wont unlock with the fob either. All other doors OK including the buttons seem ok.
Got these codes from a quick scan just a few mins ago, but will try to scan again tomorrow as I have clearded them now and need to have a drive:
3 Faults Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 174
Mileage: 62592 km
Time Indication: 0
Date: 2017.10.14
Time: 00:50:52
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 201
Mileage: 62656 km
Time Indication: 0
Date: 2017.10.27
Time: 21:42:56
00190 - Driver's Door Handle Touch Sensor (G415)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 170
Mileage: 62768 km
Time Indication: 0
Date: 2017.10.31
Time: 00:15:36
Old 13th November 2017, 04:36 PM
and this one, odd that it states 0Km however
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 14
Reset counter: 174
Mileage: 0 km
Time Indication: 0
Old 13th November 2017, 11:14 PM
neeldub neeldub is offline
I'm having a similar problem where my driver door doesn't unlock when you touch it..all other doors seem to work fine.
Because the locking switch isn't working on the handle either, I'll be changing it with a brand new one which i got from TPS for £96. I painted the base coat myself and paid a local reputable bodyshop £20 for them to apply the clear coat lacquer.
I'll take some pictures of the process and post soon.
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 13th November 2017, 11:36 PM
H-M3 H-M3 is offline
Please take pics for us Learners neeldub of the whole process
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 14th November 2017, 08:05 AM
Hi
I don't suppose you have a link to the part you ordered?
Thanks
Alex
