Old 30th September 2015, 04:24 PM
Default Lets talk battery chargers
My D3 does not get much use for weeks on end, and then I'll do a 400 mile return journey.
For example in the last 5 weeks my D3 has been used almost daily, yet it has covered just 55 miles.
As a result I think that the car is consuming more power than I am putting back in, that coupled with the slight battery drain issue is leading to less power.
After 5 weeks I am getting up in the morning to find that the BCM has turned a lot of stuff off, so keyless entry is disabled and the light in the door is not flashing so I need to use the unlock button on the key to open the car. Once inside I can start the car with the start button, and the battery monitor is down at 15% or so. After driving to work, its up at about 80%, but I switch off at that point. Same at the end of the day, except I usually leave the engine running for a bit to get the battery meter to 100%
We all know the battery meter is just measuring voltage, and I confirmed that with the meter on 100% the battery is still receiving current from the alternator, which once charged the BCM stops.
So looking for a charger really, not to expensive but something I could use say weekly to topup the battery. I've tried a big solar one directly on the battery but I don't think it was doing much as they tend to be to help maintain a well charged battery.
Battery is fine, its 20 months old and never been run fully flat and always starts the car without issue. The car will be fine for several weeks after the long run, before getting back to where I am now.
Old 30th September 2015, 06:22 PM
47p2's Avatar
47p2 47p2 is offline
C-Tek chargers...
Nite Blue 3.0L SE Quattro
Old 30th September 2015, 06:35 PM
CTEK MXS 5.0 can maintain 110Ah like ours.
Not much change from £60 notes though.
Matt
Old 30th September 2015, 07:23 PM
Check out this one available at Lidl from tomorrow. http://www.lidl.co.uk/en/our-offers-...&id=27134&ar=3
I have LCD version of the same charger https://www.youtube.com/watch?v=NO9MWevR1yk (not me in the video ) and it's been great to top up or keep charged battery but being 3.8A it takes long time to charge from flat. It takes probably around 20 hrs to go from 20% to 80%. At 80% it cuts current to 0.8A just like C-Tek chargers so it takes another 24 or so hours to get to 98% so you are looking at 2 days or more to go from flat to fully charged.
Old 30th September 2015, 09:24 PM
manny this could also be caused by a faulty BCM as that is exactly the behaviour exhibited when they start to go a bit funny. Suggest you plug vagcom in and recode the battery by adding 1 to the previous coding and digits and then the BCM thinks you have fitted a new battery and you don't seem to get the same issue again for ages if that's what it is. Worth a try anyway.
Old 1st October 2015, 06:21 PM
I am now more than sure the reason for the overnight battery issue is the boot electrics. Last night I needed to access the boot after driving home from work, and this morning the battery was fine and just under 100% charged on the meter. Same this evening, 100% charged after sitting in the car park all day.
So what on earth can cause issues with the boot electrics. I know that if I close it manually I can sometimes press down on the supposedly locked boot and here another click like something was not engaged properly. My electric boot is missing the little spring so it does not close itself without opening up again. I dont think its the boot light as that goes off after a short while if you leave the boot open anyway.
I've still decided to get a charger, and may go for the ctek one mentioned, at 11 years old she is developing electrical gremlins.
