Old 4th April 2015, 03:50 PM
The 20's with new Michelins had their first proper run today.
Somehow ended up in a mini-convoy with an old restored Porsche behind me (Audi driver normally) and an S4 behind that on a nice winding road. Then we caught up with a newish S4 (the supercharged variety) for a "sprightly" run to our breakfast venue.
Handling is excellent.
And I discovered that an S8 is faster out of a sharp corner than a older V6 RS4 Avant, probably due to turbo lag.
Old 4th April 2015, 04:51 PM
We also did a sort of comparison between the centre caps on mine and Rob's (Professor Peach).
His were not as flush fitting as mine and one we looked at more closely came off VERY easily and was quite tricky to get back on.
We didn't study that closely, but it looked like his had the same potential problem as mine had initially, a spring ring that had a gap too small to allow enough "shrinkage" to clip fully in.
Old 7th April 2015, 12:49 PM
Professor Peach's Avatar
As much as I love my D2 S8 Andrew, I can't think of any situation where it's faster than my B5 was (if driven correctly) to be honest.
The wheels look really excellent in the flesh though! And the breakfast was of course excellent too!
2016 S3 Sportback
Old 18th April 2015, 09:02 AM
I think I've found one possible cause for the fitting issues of the centre caps.
Studying pictures online (of my cheap Chinese ones and similar) vs the genuine set I have just acquired, the four retaining lugs that are pushed out by the spring are subtly different.
The OEM ones have a vertical "slab" that is 10mm wide and 2mm deep with a couple of "buttresses" at the bottom. And of course the two-way sloping wedge section at the top with the spring pressing on the back.
The copies have the same slab, with buttresses, but part way up thicken to maybe 3.5mm and that extra thickness continues in the "wedge".
This makes them overall maybe 3mm larger in diameter where the lugs have to penetrate the hole in the centre of the wheel and of course much less flexible.
Enough to make it difficult or impossible, unless (as I have) you use smaller/weaker spring rings and bend each of the lugs in a bit.
I'll try to attach some pictures to show the difference.
Taken from different angles and just "snipped" from t'internet but the difference is pretty clear. The OEM ones have slimmer, straighter lugs and the copies are just too bulky.
ID:	10502   Click image for larger version
Old 29th April 2015, 06:19 PM
The genuine centres (chrome effect, not brushed) were pretty tarnished so I've dismantled and fully refurbished them:
And they are a much better/flusher fit (cheap Chinese copy lying on the ground):
Old 3rd May 2015, 07:02 PM
Just a final footnote on the cheap Chinese centres which I've now taken off and cleaned, with the intention of spraying with lacquer and keeping as spares.
The base of the retaining lugs (where the little triangular supporting buttresses are) are all showing very obvious signs of overstretched plastic that would probably fail eventually.
I guess this is down to a combination of poor material (less flexible/resilient) and the thicker lugs which means they have to bend more to fit.
The lesson is: Don't even think of buying cheap copies with the light beige plastic material, you need the grey OEM ones.
Old 3rd May 2015, 07:23 PM
talking from bitter experience with our old A6 you don't want them falling off at speed either - marked a rim fairly badly when one did on that when we first bought the car!
Old 5th May 2015, 12:48 PM
Indeed not!
Just looking again at the design of the copies you can see why they are difficult to fit:
The lugs that are marked as 24mm from tip to base are only actually thin at the very base, maybe 6mm or so.
Almost all of that has those triangular buttresses and above that it's thicker and quite rigid.
So almost all the flexing takes place at the 2mm or 3mm thin area at the top of the buttresses. Which is why that is showing stress marks on the ones I removed.
The OEM design is the same (thin) thickness from base up to the "wedge" at the top. The wedge is also shallower.
So they have a whole 15mm or so to flex and less distance to bend as well.
I also suspect the OEM material is more resilient.
All of which says that the Chinese ones have almost been designed to fit badly and break quickly.
