Old 26th January 2016, 04:36 PM
Trying doing a test on the compressor first using vcds with the help of the label file from the following thread
http://forum.a8parts.co.uk/showthread.php?t=10823
If you watch the following video you can see how to test the compressor, ignore the other waffle as it was related to somebody else's issues.
If you watch until the point of login then skip to 14:30 you will see how to test the compressor
https://youtu.be/OU5SBmHQIfI
Old 26th January 2016, 09:56 PM
Conquistador's Avatar
Thanks Del. Copied the label file across but still have an error when I select pressure accumulator charging and doon't have the on/off/next button up the top. Measuring blocks shows compressor temperature at 28.0c and 11.39 bar pressure
Only suspension fault code present at the moment is:
Tuesday,26,January,2016,22:51:13:33490
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 52
Mileage: 167520 km
Time Indication: 0
Date: 2016.01.23
Time: 18:11:42
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th January 2016, 09:34 AM
Thats after entering the security code right?
If you don't enter the security code you cant run test either.
Before basic settings click on security-16 and enter the code
Also if you do get at it remember the test will only run for a minute, i had to do mine a few times to to get to 16 bar which is the max
Old 27th January 2016, 01:10 PM
Yeah I definitely went through security access, then when I clicked Do it! after typing 08367 I got a little error box saying it wasn't possible.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th January 2016, 05:53 PM
mannyo mannyo is offline
I wonder if the fact that the basic settings are messed up are preventing any access.
Manny
Past
Old 27th January 2016, 06:20 PM
Have a go at the 31564 security code and try another calibration set up see if it lets you
Old 27th January 2016, 08:45 PM
Nope, can't select any of the damn options now...
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 28th January 2016, 04:16 PM
Well the car went into Audi today for an EVHC anyway, and it came back fully working again with no suspension faults without me mentioning it. So whatever they did while it was in, worked.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 28th January 2016, 04:35 PM
Lee S Lee S is offline
Excellent.... now leave it alone....
Lee
2017 Nissan Leaf Tekna
Old 28th January 2016, 04:41 PM
LOL the above & great to hear its better. Whats an EVHC?
