Go Back   A8 Parts Forum > Our Other Audi Friends > TT 8N
TT 8N 1998-2006
Old 28th September 2009, 07:13 PM
gninnam gninnam is offline
Originally Posted by A8 Doc View Post
Under £4k mate
Not sure on the Golf side of things, it's 4x4 remember so the floorplan would be different I think? But yes performance is excellent.
Back today!!
Less than £4K - sounds like a good buy indeed
Shown the wife and its on her list (she is having the Focus to begin with, then see what happens after a few months - she also fancies a Nissan Figaro , but refuses to drive either the VW Van or the A8 as she says they are too big)
Keep us posted once you get the TT back
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 8th October 2009, 07:15 AM
A8 Doc A8 Doc is offline
Right here we go, pictures though not the best quality!
I replaced all discs and pads all round on the car and this one was an absolute pig. I kept checking it and it all seemed correct, I could only assume I had damaged the caliper winding it back in? After 2 hours I got sick of it and then noticed the disc guard. It just happenned to be scraping the disc every so slightly causing the noise. Pushed it back and it's gone. Happy days!!!! Also the bolts for holding the disc on is an M6 20mm for reference incase you need to know and it's a machine screw 1 hour spend drilling the snapped on out :roll:
Airbag module needed replacing. I got to this one, disconnected the battery and replaced it. One plug, coded it to the car, erased all faults and airbag light went out. Big big big sigh of relief!!!
Faults this car had them all! And a nice bodge of the clock spring. So I put a new clock spring into the car from the TT 3.2 convertible and the horn works again. Yey! Unfortunately for some reason I can't calibrate the steering angle sensor.... I think cos it is off an 04 plate car they have a seperate sensor? Anyhoo will swap this again later...
Steering wheel all back on properly with the cluster.
Steering column needed a bit of bearing grease on the joints as it was clicking when cold. Sorted
Driver side seatbelt bolted back in, it runs all behind the strut brace you see in the picture, feeds through a metal loop at the top and out of the door card.
Passenger side one done.
Rear card on, all with push clips. You just have to pull!With all the seats out.
All the interior fitted in. Car also has ISOFIX fitted so bonus
New wheels on, see the M3 in the garage poor thing
Shiny genuine wheels with brand new centre caps and tyres
BAM engine. Bog standard apart from a custom remap by meeeeeeeeeee! Running an N75J valve.....
Car complete just needed a polish!
Quick clean and all done MOT done, tax done and the missus absolutely loves it!!!
Enjoy
Old 8th October 2009, 09:35 AM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
Awesome work mate, well done
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 8th October 2009, 11:59 AM
Agree - cracking job and liking the single post too
Andy.
Current cars:
BMW i4 M-Sport
Last edited by Conan_the_Librarian; 1st November 2009 at 07:31 AM. Reason: Correcting................. :P
Old 12th October 2009, 07:36 AM
Ooops on the double post if someone can remove that?!
Thanks guys Enjoyed doing it, the missus loves it to bits!
