The passenger side should be easy to fix as it only batters against the scuttle plastic. Also, check that the passenger side wiper blade is the proper curved one. If its been replaced by a straight blade then it may need adjusting. Remove the passenger arm from the spindle and re-mount it a few degrees so that it travels further across the windscreeen but doesnt hit the scuttle on the down stroke. You might have to sacrifice the neat, out-of-sight parked position.
