seperate instrument cluster
Hi chaps
getting the cluster out is is fairly straightforward. Separating the clocks from the front cover is easy enough However I want so separate the front perspex from the black piece with the gauge holes in it. Its not obvious and I don't want to risk breaking it. Any tips? |
If I remember correctly it's just screws and snapped together.
Del |
I think this Audi pages post shows where you how to do.
http://www.audipages.com/upgrades/dashrings.html
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ) 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Ibis White |
thanks but alas not it shows the rings attached from the back whilst leaving the perspex cover over the apetures in place
I'm pretty sure the clear face is plastic welded to the black surround and does not come apart. I've not looked closely at this in the D2 but all the other contemporary models are done like that.
The rings push through the holes from the back though. Why do you need to take the front apart? |
you know how CSI show superglue in a sealed bag showing up fingerprints well it seems the cluster is sealed sufficiently to achieve the same thing
I now have a misty inside of the perspex that was not there when i put it back together not to mention squeezing the chrome rings through a gap smaller than them has left them bent out of circular |
