Recommendation for bluetooth unit for music streaming please
I'm looking to stream music and will need a bluetooth thingy to do this. Does anyone have any recommendations in this direction? I'm actually not bothered about phone, just music streaming!
Ideally I would like it to fit in one of the armrests to keep it out of sight, if possible! Plus how is this actually outputted (is that a word??) through the RNS-D? I've heard someone using CD 1 for this, which would work for me as my CD changer doesn't work for me!
2002 D2 S8 - Avus Silver, Valcona red leather, Dark Myrtle wood inserts, Heated rear seats, Heated windscreen, Auto dim rear view mirror, Bose, Xenon Plus, Servotronic, Extended leather, Heat & UV Reflective glass & Ski hatch. Gearbox went bang but she's sleeping safely away. |
I have an XCarLink. This one I think:
https://www.xcarlink.co.uk/product.p...1&cat=4&page=1 Sound quality is reasonably good although the output seems a little low (I have to turn the RNS-D volume up higher than I do for other sources to get the same level, even with the phone's volume up full). I find it's more than loud enough when turned up though. The USB socket is for convenience/charging only (not for connecting devices or pen drives) and you don't need to connect the mic if you don't need to use it to make hands-free calls, so you could just hide it away behind the dash if all you need it for is to stream music via Bluetooth. If I remember correctly, you just unplug one or two of the RNS-D connectors and plug the XCarLink in-between (using the male/female connectors on the supplied wiring harness). To select it on the RNS-D you just choose CD but it is selected alternately so you don't loose the ability to play CDs. So, if the first time you select CD playback your CDs play, cycle through the sources again and the next time you select CD playback you should hear your XCarLink device. Once selected the RNS-D should remember the source so you don't have to keep reselecting it each time.
Probably a bit OTT if that's all you want, but my XCarlink has that capability, though Bluetooth is actually an add-on option to the basic unit.
Edit: I posted at the same time as Mark so didn't see his post. I have a different unit to him, the "full fat" Xcarlink which plays from USB, SD, phono and (optionally) Bluetooth. It has the same connection method with the flip-flop on the CD. I use my CD changer so I find that really handy. I don't have Bose but the sound levels are consistent with other inputs so I've never noticed a problem.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 6th July 2018 at 10:29 AM. |
I have a Parrot kit (here - https://www.parrot.com/uk/car-kits/p...arrot-mki-9200), which works beautifully, and keeps the full Bose sound quality - which isn't always the case, apparently. Mine routes through the CD input, but as you've noted, that's not an issue for you.
I have the parrot screen on the small trim panel just by the drivers door, which is pretty unobtrusive, but you can choose to have it out of sight instead if you prefer that.
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ). Silent and deadly, and very fast... But not as fast as Ian's M3P- (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ) Green. Fragile, but beautiful. (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
The Dension Gateway is pretty good too. I used Dean's in Big Red when I drove her home, and then swapped it over to his S8. Sound quality is pretty good, and it does hands-free. Plugs in to the CD changer like the others do.
Ive got a Dension Gateway on my D3 daily and its been great, never missed a beat and still sounds good
Thanks everyone, going to see a local auto sparky today to have a chat so thanks for the suggestions. Basically he has said get whatever you want and I'll fit it so this has been really helpful, thank you.
Now I need to crack the reversing camera!
