#31
Have you done a VCDS scan since fitting it? I think it's in 35, Central Locking.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#32
I haven't done that I'll scan for codes and see
#33
Did you check the connector before you swapped it over? Its quite common for the leaking battery acid to eat the terminals in the connector.
#34
Don't know if central locking pump is playing up as boot lights stopped working again. |
#35
Hazard lights don't work either when car is locked.
#36
Little update. Horn does work, accidentally set alarm off and it was beeping. I think the hazard lights and horn not sounding when locking/unlocking is coding issue.
#37
They certainly are optional through coding.
#38
All coded in 2 flashes when unlocking, 1 flash + a beep when locking. Well chuffed.
Also figured out why boot shows open at all times, little plastic part inside latch is broken and that also operates boot interior lights. Fu**ed up and didn't attach the rod that operates latch back on and closed the boot so looks like I'll be smashing the light up to open it |
#39
Nooooo! Is the solenoid for the electric release still attached?
#40
Sorry to hear about the latch rod, do you have a ski hatch? There's also a method documented somewhere of cutting through behind the numberplate to get at the latch when the rod is detached. Edit: Have a read of this: http://forum.a8parts.co.uk/showthread.php?t=12012 though it may not work, depending which end is detached.....
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 2nd December 2018 at 06:23 PM. |
