Old 4th October 2018, 05:29 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Engine/diesel/exhaust smell through HVAC
Anyone else had this, not all the time, and if I recirculate air, the smell goes.
Was wondering if it might be an exgmhaust leak near the pollen filter.... With the engine idling it’s quite smelly under the bonnet, but I cannot see anything obvious.
2007 Mini Cooper S R56
Old 18th October 2018, 07:34 PM
My EGR cooler shut off valve leaked smoke. It was sooty around thar area, I could see the haze at night with a green laser pen shining it under the bonnet.
It is a butterfly valve operated by vacuum and whatever the shaft ran it had gone, bearings or whaever leaving it loose in the holes so smoke could escape.
Old 18th October 2018, 07:40 PM
Johnmed's Avatar
I’m thinking EGR, or PCV, hopefully not exhaust. It’s smokey under the bonnet and nearside wheel arch too. Fuel consumption seems to have suffered of late too. Got it booked in to local Indy on Monday, as I don’t have the time at the minute to faff about.
Cheers Snap.
Old 26th October 2018, 12:28 PM
Johnmed's Avatar
Local Indy have replaced an exhaust piece, I believe between the manifold and the turbo. Compensator Pipe he called it. Not the nicest of jobs apparently. It was cracked. Said the turbo wouldn’t have been spooling up properly.
Quite the labour intensive job just to get to the thing, all very sooty. Said he could’ve probably done 7 other jobs on cars, in the same time.
Blinking cars!
Old 27th October 2018, 12:06 PM
Ouch, never heard of that! GLAD YOU GOT IT SORTED!
Old 27th October 2018, 12:11 PM
Johnmed's Avatar
Ouch with 4 digits attached!
