Old 22nd November 2013, 12:23 PM
Claymore Claymore is offline
Default 3.0 TDI Inlet Manifolds..
Guys..
I'm guessing that this one has probably been disussed numerous times before.. if so can someone please point me in the direction of previous posts?
My MIL lamp came on a few weeks back and i discovered that the spring clip holding the actuator onto the end of the inlet manifold (passenger side) had shattered.
Result was that the actuator/connector rod from the motor wasn't connected and therefore shooting out problem codes..
I bought the little repair kit from Audi with new style (supposedly improved) connecting rod, actuator knob and spring clip.
All fitted in no time, can see the motor opening/closing the flaps etc as they should. Fault codes all erased, but within no time I'm now getting code of P2008 suggesting motor problem..
Anybody come across this before??
No other codes suggesting upper/lower limits not being reached.. just the P2008 (bank 1a)..
92k miles on the clock if that adds any clarity..
Old 5th May 2014, 08:35 PM
onetwentie onetwentie is offline
Hi there
did you manage to fix this problem?
Current: 2007 Audi A8 3.0 TDI SE Quattro -
Old 5th May 2014, 09:52 PM
I had a similar issue on my 3.0 Tdi Q7 - Bought the repair kit from Audi and did both sides. Not heard a peep out of it since..... (touch wood)
Old 5th November 2014, 10:41 AM
manca manca is offline
Digging up the buried I know....
Has anyone done this who might be able to supply the part number? I need my drivers side done, best to do both I guess.
