Old 13th February 2014, 11:44 AM
3.7 slp 3.7 slp is offline
Default type of front wheel Bearing
Looking to save some pennys up for a new passager side front wheel bearing that is giving a rumble on that side on right turns . Just looking to see if the ones on the front of my 2000 FL 3.7 would be a push fit unit our if it comes in the housing ..which looks a let easer to change and work on with less strip down...
if anyone would know it would be a great help
Thanks all.
Old 13th February 2014, 12:19 PM
Here you go (attached) - RRP is £67-120 depending on which of the 3 versions of Item 2 you need
Old 13th February 2014, 01:02 PM
Great thanks you that ..looks like good new as it should going by this be the bolt on type which looks alot easer to fit..
Many thanks for that Adrian .
....off to count my pennys now and get a quote for the job
Old 14th March 2014, 09:40 PM
SilverS8 SilverS8 is offline
Any idea what the correct bearing is for the FL S8 ?
Scratched my head a few hours after checking Etka...
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 15th March 2014, 06:47 AM
If you've got 18" wheels (or more to the point it came from the factory with 18s) and your VIN is later than 4D-1-006 001 (where - is unimportant VIN data) then you need 4F0 598 625 A - in fact most appear to use that part even if it's not clear why they are listed separately in Etka!
If in doubt ring the main dealer and to check a price and get them to confirm the correct part number based on your VIN
Old 15th March 2014, 07:31 AM
Appreciated
2000 Silver S8
