Sloshing sound and wet passenger feet!
Well yesterday I heard the dreaded sloshing sound of water when cornering. The car also dumped a load of water over my passenger's shoes too. She wasn't impressed one bit, and nor was I
What should I be tackling first? The orange plug which is prone to blocking? Is this the result of the windscreen tray blocking?
Currently '8-less Previously: - Aqua Blue Pearl D3 S8 - Kamut Beige leather, ACC, B&O, factory RSE, solar sunroof, electric blinds, ski bag, Homelink, comfort headrests. - Aqua Blue D2 S8 - Grey leather/Alcantara - D3 A8 3.0 CVT - D3 3.7 V8 |
Any or all of the above.
Orange drains will be blocked so clear them first and dry the interior out. Then you need to figure out why and what the water source is. The aircon slowly fills the tray that the orange drains are meant to empty, but if it all appeared quickly it's probably rainwater from the scuttle drains being blocked and overflowing into the interior. Rainwater also brings in crud that blocks the relatively small orange drains quite quickly. If you decide to attack the scuttle drains with hot water and detergent (worked for me eventually) do it while the interior is apart and you have the orange drains pipes diverted into a suitable capacious collection device.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 26th July 2015 at 10:29 AM. |
I sometimes drive with the radio off (to hear the V8 of course) and have never heard sloshing before. We've had torrential rain this weekend which is still going, so I expect that's why. If it clears today then I'll take a look.
Had the windscreen replaced about a month ago too. Could this affect anything? If I can't fix the problem today then I won't drive it any more until I do.
If it's after a load of rain. have a go at the drains in the front wheel arches - they're very quick and easy to do. You'll find a rubber 'teat' at the top rear of each front wheel arch (no need to remove the wheel).
Just give them a good squeeze (or remove them!) and watch the water drain out all down your arm! It's a 2 minute job.
You could try pressure washing the underside (ideally with an angled jet) in case it's just the sunroof drains that are clogged and it might be enough to get you out of trouble. Mine leaked once or twice from the area around the sunroof controls and that worked to clear it.
Hmm OK, a few options then. I used a long bit of furry pipe cleaner on the sunroof drains (which comes out near the door hinge) a couple of months ago and it cleared some gunk out. I poured 500ml of clean water through it and 500ml came out the end.
I stripped the front carpets out and the undersides of them were soaked, as was the footwell as you can see. I've located the orange plug thing and will pull it out a bit later if it stops raining for good: Jim, I think I can see where it should be but I can't see any teats to squeeze! Water is steadily dripping out of a hole there though
