Old 27th February 2010, 12:24 PM
topgolfer1's Avatar
topgolfer1 topgolfer1 is offline
Default armrest phone prep to ipod.
Hi all,have aquired a dension ipod adapter,and was thinking of having the ipod in the armrest,where the phone prep is located.My query is whats the easiest route to get the ipod wire to the armrest,and how much work is involved in getting it there.I have seen on Tyresmoke, pictures of MKoneman(James),install but no info on how.
Hope we are all well?
Cheers for now
Rich
Old 28th February 2010, 07:17 PM
This would be easier with photos, which I dont have so here goes verbally (as it were)
Its an armrest out job, so firstly you need to pop off the chrome top trim off the center of the armrests. This is easy with a flat blade in the groove.
Removing it is more tricky, it takes a combination of lifting up the armrests and gentle wiggling, but it works.
That reveals a (6mm I think) allen bolt, which when removed will render the amrests removeable, but being ally mounted on ally, then tend to seize on. A few firm bashes on the armests will loosen this bolt.
Before you remove it completely, there are cables already in the armrests which need disconnecting. In the cubby hole underneath the armrests is an inch (ish) square plastic plate, remove this by popping it off with a flat blade. Fettle around under there and you will find a connection for armrest illumination. Disconnect this, and off come the armrests.
Next, dismantle the armrests. There are colour coded plastic trims running all the way down both sides of each armrest. These just pry off, and they reveal a handful of small (torx I think) screens. Remove these, and the storage bins inside the armests come out complete, including the phone cradle where fitted.
Finally, if you look inside the armrest with the bins removed, you can see a locking pin which is anchored with a small (torx again I think) screw. Remove this screw, and the locking pin and the individual armrests will come off sideways.
You can then see clearly how to feed fresh wires in/out of the armrests...
Refitting is reverse of removal.
Enjoy
Old 1st March 2010, 02:34 PM
topgolfer1's Avatar
Cheers Ian for that,will let you know how it goes.
