a8 d3 1st postion ignition
as above has any body been able to find one or a live only when radio cd etc comes on
at the moment my subs and other links I have on the car are switched on. when term 15 comes on ie open a door or just kicks into life and of course this does not do wonders for the battery any help would be |
The radio etc are on a T30 feed and are switched on off by the energy manager via CAN. The T15 relay is under the steering wheel. I think some people have made another T15 relay in the boot by using the T15 from the parking aid for the coil switch.
I don't know how the systems are wired up on the D3 but on the D2 I discovered that, in order to run the CD changer, there's an "always live" in the cable to that (so you can eject cartridges etc.) and a "RNS on" 12v feed as well.
The latter is live when you turn the RNS on by whatever method - e.g. ignition or just the "on" button without ignition. I used those, via a relay (and fuse), to power my DVB-T tuner. The same supplies also run my XCArLink unit. Maybe the D3 has some similar and accessible circuits?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
been all over the car to find an acc point did the wifes 2005 a3 ok via ign sw taking a feed from the module under steering column
more difficult on d3 as I don't use key because of finger print start I'm just wondering if the aerial amps switch on with radio and not term 15 or 30 have to have a look interested on what you guys have done with extra relays I also bought a can control that is supposed to give an ign output but it could not talk to the a8 can signal so another 50 quid wasted the joys |
