Old 29th October 2014, 10:48 AM
Lloyd Lloyd is offline
Default Boot lid inner trim removal
Any tips on getting this off with out wrecking it as my boot light has fell inside
Old 29th October 2014, 10:51 AM
It's dead easy, takes 5 minutes.
Take the warning triangle out and remove the fixings holding the mounting clip.
Remove the screws inside the pull handle. Take off the rear lights access panels.
Work round the edge taking out all the felt-covered screws.
It's then just hanging on a few clips and will just just pull off. IIRC there are two clips in the centre that are bigger and stronger and need care to realign when refitting.
Old 26th February 2019, 12:43 PM
johnny_quattro's Avatar
Default Resurrecting old thread once more...
I've just managed to break the OSR number plate light housing as one of the bolts is stuck and is just turning in its housing. This is probably all due to excess water rusting up the bolts for the number plate lights in my boot which I think I've now fixed with Sugru.
Thanks Andrew (HPsauce) for this nugget of info. I'm going to need to take off the boot lid inner lining to fix/repair.
Old 29th October 2014, 11:02 AM
Just reread this, what light, there are none inside the lid?
Old 29th October 2014, 11:20 AM
roboblob roboblob is offline
number plate light ?
Old 29th October 2014, 01:01 PM
The light just on the inside left of the boot lip can fall inside.
You need to remove the bolts behind the luggage net 'eyes' and, possibly, one of the 'hockey stick' side trims that are secured by 2 of those 2-piece plastic fasteners (pull out the centre part first to remove the outer part). Then just pull - there are clips, but they'll give OK.
Old 29th October 2014, 01:40 PM
I need to learn to read properly too
its been a long day
Old 30th October 2014, 08:36 AM
It's a PF car and occasionally when I open the boot there is a light shining through a slit that looks like it may have been the boot light but now that I think about it I think it's the rear lights shining through said slit it as its smack bang where the warning triangle would be ( no excuse for this much stupidity and I'm not even blonde although my missus is , does that count)
