Old 2nd February 2015, 06:30 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I have both ACC and non ACC wide dis clocks if anyone wants any. A8 not S8 ones ive done a lot of changing around recently so have plenty of spares
Diesel?
[center]
06 3.0TDI Quattro:
Options:
Old 3rd February 2015, 09:29 PM
Hello, I got mine, need a bit of a clean as a big spec of dust behind the clear plastic - but should I fit it and drive to Audi? or drive with old one in and trim removed and new one in a box? If so, why do they need the old one? to witness mileage?
Also, anyone know any non-dealer who can remove CP with Abrites?
Old 4th February 2015, 01:56 AM
Talk to the master tech before you go thee and find out what he needs. I just drove there after swapping mine. CP just means lots of things don't work but not badly enough to mean you can't drive it there.
Old 9th February 2015, 07:22 AM
Cheers chaps, cluster stripped and cleaned and fitted.
Tried to avoid CP by removing Instruments -17 from CAN Gateway installation list to to avail.
With CP Active, the cluster works normally for about a second when you press START, then it goes dark and only the speedo works nothing else, even kills the illumination on all of the dashboard and stops the HVACs from lighting up (still work through MMI). The DIS is lit up red like an electric fire.
One puzzling thing is that the [0.0] & [CHECK] buttons would not plug into the new instruments, when I finally had enough andgot a torch on the plug, I found the plug inserted into a 'terminator' as though the 2008 car my cluster is from doesn't have these buttons? Anyone know what the story is there?
Just need to tap up the dealership now
Old 10th February 2015, 01:57 PM
Well, Sytner Nottingham Audi looks to have had another big change of service staff including Head of Business - all the competent, friendly and familiar faces gone and now they all seem to change with every visit.
The trainee service receptionist (quite rightly) got a workshop worker to come and clarify what I wanted - he grinned and said it's not possible on used parts (with a haha! look) so I told them I knew several others who had done what I wanted to do without a problem, and he changed his story to: we need to upload all the data from the old one and into the new one (pause) do you have the old one? I said yes and he looked disappointed and said I know you have all the receipts etc.. but we don't take component protection off used parts for ethical reasons! (with a haha got you there! look) We just don't do it ourselves for ethical reasons.
I gave the benefit of the doubt and thought that maybe he was being cautious due to the trainee in case she mentions it to someone.
He then started saying that the used cluster had the immobiliser in it so I knew he didn't really know what he was on about - I mean, how can I drive their with another car's immob fitted not that that's the case.
***EDIT***Found a few indi options but cost more than the cluster so far, but there is one near where I work I'll visit them in the morning.
Old 10th February 2015, 02:26 PM
My local indy in Crawley is upgrading their systems to give them full server access to Audi Germany for doing CP removal. I imagine others round the country will follow as more vehicles that require it come out of warranty. No good if you're replacing parts as a business but need to pop it down the main dealer every time CP kicks in!
Old 10th February 2015, 08:56 PM
mannyo mannyo is offline
I believe that M-A8 used these guys in Harrow.
http://www.audivwsc.co.uk
To remove CP from his cluster, they have done work on my D3 without issue in the past and Kristof who is ex. Audi Master Tech knows his stuff.
Manny
Past
Old 13th February 2015, 04:17 PM
Went the 110 miles each way to Harrow, well worth it, great guys, in and out in 15 mins.
New cluster (2008MY) has brighter whiter and redder illumination too, and the quality of the DIS LCD is much more like the newer models. Very pleased with it and it has the MPH function without any VCDS work needed.
Just need to add 207,000 to the mileage!
Old 13th February 2015, 06:08 PM
Thats certainly a nice looking display.
Manny
Past
Old 13th February 2015, 06:12 PM
Looks great!
Out of interest, how much did they charge you for this 15 minute job?
Audi charged me £60 for mine and that was trade rates lol
