Old 14th March 2012, 01:22 PM
Default APS Parking system sensors
Got a quote to fix the parking sensor (front right), been told that its best (Audi reccomended) to do all four at the same time, so with that and bumper removal , painting to fit etc comes to £600.
Im not £600 bothered to get this done, but i thought maybe i could turn off the front set of sensors and then it would work fine with the rears. so i unticked the box for APS front in the hidden menu and rebooted the MMI.
no change
hooked up vagcom and cleared the original fault and tried again, no change, the fault still reoccurs in vagcom so the car is still "seeing" the front set. I couldnt find anything in the adaption chanels of the parking module that turn of front and rear,
anyone got any ideas if its possible to turn of the front set only with vagcom ?
Old 14th March 2012, 01:25 PM
Unplug them from the sensor, then recode it. The fronts are a seperate plug from the rear.
Though I'd just do the dodgy sensor.
Old 14th March 2012, 01:30 PM
seems a resonable idea, where would i unplug from? and when you say recode it, my options apart from unticking it from the canbus completely seem limited to buzzer warnings front a rear etc.
Old 14th March 2012, 01:52 PM
If you take the carpet panel off the left hand side of the boot, you'll see it on the sheel arch, with three plugs going in.. Can't remember which one is the front (middle maybe), and see how it behaves. It may need recoded with vag-com to tell it that it's a 4-way instead of 8-way
Old 14th March 2012, 02:14 PM
if i unhook it, the car will think all 4 have failed, so ineed to find where to recode it first, and mybe just the recode will be enough, theres nothing in the parking module on vagcom
Old 14th March 2012, 04:14 PM
My A6 has a duff front sensor and have only been told I need to do the one - worked out at 90 quid for a new one, with painting. I have it in my grubby paws and plan to fit this weekend if the weather is OK
