Old 17th March 2018, 09:17 PM
So... discussion point: how much is it worth to host a miner at my place?
Its always cold, even in the summer and I wouldn't mind some extra heat. I have plenty of space to build a server room where the noise isn't an issue. Electricity is 14p a unit unfortunately, but I do have 120KW of it.
I'd already have some miners in there had I not spent all my money on D2s!
Old 17th March 2018, 09:46 PM
I would be interested in hosting but that electricity price would erode any potential rental costs I could offer. My electricity is price is £0.11625 day rate and £0.45773 night rate which works out average £0.101415833
Is there any chance you could shop around for your own electricity supplier for better price instead of using your landlords who probably have not changed it for years? I would assume as business user you could get under 10p.
Just to give some ideas there are some data centres in/near London that offer S9 hosting for £210/month which is a bit too much for me, my costs to run S9 is about £110/month and I would be happy to pay £150 for it to be somewhere else but at your costs it will be £150 just for electricity. I was looking at locating some at my mother in law's house in Latvia but electricity is more expensive there but might consider brother in law in Russia.
Old 17th March 2018, 10:16 PM
In another news I overclocked A3 to make most of it as the profitability is dropping. It did not quite make 20% overclock some are reporting, only about 12.5% but still OK, it's only about £1/day extra after extra electricity costs but every little helps like certain supermarket says. Sia does seem like a good coin with a lot of future and undervalued for now so I am just hoarding coins and keeping them. ATM you can buy 1TB storage on Sia network for about $0.60/month comparing to £7.99 on Microsoft One Drive for example. They just need to increase PR and the costs and coin value will go up coupled with the mining difficulty.
Old 17th March 2018, 10:27 PM
Unfortunately I can't get a better deal as its technically one building with one incoming meter. Its then split off to the various tenants on our own meters. There is an off-peak supply board but its not in use so I'm not sure whether I can make use of that. It is annoyingly expensive - I pay 13p at home, which is still expensive compared to yours.
I will have a word with the landlord and see if there's anything we can do.
Old 18th March 2018, 09:21 AM
Takemetothepub Takemetothepub is offline
Halong Mining just pushed out their CryptoNight miner,
https://halongmining.com/shop/dragonmint-x1-miner/
Ethereum miners will be next from the rumour mill I keep hearing....
2005 6.0 W12 Quattro SWB - Need an OPEC membership to run it!
Old 18th March 2018, 11:04 AM
That's the slowest of 2 they have announced but they just keep announcing new miners but have still to ship any. Their first miner T1 or I think it was called T16 at the start was supposed to ship beginning of March but nobody has received any yet so it remains to be seen if they can deliver.
As for Eth miner I understand it would be quite expensive to create ASIC because you need at least 4GB RAM for DAG file and realistically 8GB for futureproofing. You cannot just connect hundreds of ASIC chips to that memory because couple chips would consume the available bandwith. So really you will need like 100 lots of 8GB which would be 800 8Gb memory chips. With the memory shortage and rising prices memory alone would cost $7-10k, add on other costs, R&D and profit margin you would be looking at least $20k for a miner that does hashrate of 100x RX580 cards. It's not too bad considering that 100 cards would cost more than $30k. But who would buy such a miner with Ethereum set to change from PoW to PoS. So unless cheaper, faster memory becomes available I do not see it happening.
There are some custom miners for Eth like Antminer G1 and G2 but they are not ASICS, it's just a custom motherboard using low power mobile PC components and 8x RX570 or GTX1060 cards in it.
Old 18th March 2018, 12:04 PM
Managed to get some pics without showing the mess Just for size reference the inside diameter of that ducting is 315mm.
Can't be any messier than my cellar. With no garage or usable loft, my cellar is piled high with stuff. Took a while just to clear a space large enough for the miners (I'll try to get some photos up when I have time).
That ducting is huge. I stuck with 100mm, mainly because 100mm ducting adaptors were readily available for Anminers. I like how you've made the ducting so much prettier though, by tying it up with red ribbons and bows ... I just used back cable ties.
I suppose if you want to make it worthwhile for yourself and the rentees you'd have to take into account what you would normally pay for heating. Subtract that from the cost of running the miners and set the rental charge at a level that makes you some profit while leaving enough room for the rentee to make a little profit too.
Alternatively, if you're willing to take the ROI risk, you could buy a few S9s yourself and rent them out. When they've eventually paid for themselves, hopefully in around 12 months or less, all the profit is yours.
Old 18th March 2018, 12:58 PM
Nothing! Its -2 in here today
Old 18th March 2018, 01:43 PM
I do have some 100mm and 125mm on the miners, 125mm is definitely the way to go, 100mm is restricting airflow too much and temps and fan speeds go up. Thanks for the comments about bows I did not have long enough cable ties and wanted something wider not to cut into ducting so just cut up some luggage straps and bows are so that it is easier to undo when needed.
Old 18th March 2018, 02:06 PM
I don't think I have posted picture of this before. It's Antminer L3+ with modified firmware that lets me overclock each board separately so that i can overclock 3 of the better boards and it also lets it run without fans. It is running aboout 620MH/s with 1000W power consumption and 1.5% devfee for custom firmware. It is in my understairs cupboard. There is air intake at the bottom of cupboard dorr and it is blowing warm air out in kitche/dining room keeping them warm. Thge downside is chocolate meting in top shelves in kitchen cupboards. Easter bunny looks like gravity got better of him.
