Old 9th November 2011, 09:47 AM
i had mine tinted on the front and because they are al ready tinted the result was a dark blue affect on the front windows and blacked out on the back, they look very dark but are infact legal,
Old 9th November 2011, 11:01 AM
have you a piccy to see what it looks like, and how do you know if they are legal or not have you had it tested?
Old 9th November 2011, 06:42 PM
The law requires that the windows on the vehicle allow at least:
75 per cent of light through the front windscreen
70 per cent of light through the front side windows
In most modern vehicles there is a slight tint added to the windows when they are made. If you add any more tint it’s likely to result in the windows failing to meet the legal requirements.
The rules on tinted windows don’t apply to the rear windscreen or the rear passenger windows.
Old 10th November 2011, 10:04 AM
Excuse my ignorance but is this age related too? As i have been told that the Land8 can be done front and rear the same shade.
Old 11th November 2011, 12:03 AM
Car Window Tinting Law in the UK
Vehicle & Operator Services Agency (VOSA) Statement -
The window tinting law in the UK states that the specifications are:
a) The law is for Motor Vehicles first used on or after 1 April 1985
b) The light transmitted through the windscreen must be at least 75%.
c) The front side windows (to either side of the drivers’ head) must allow at least 70% of light to be transmitted through them.
If the glass is tinted to a point whereby it lets through less light, the vehicle is breaking UK Window tinting law. You also need to consider how much the existing glass is timted by before adding any further tint as the above figures are based on total tint / light remaining transmitted
It is ILLEGAL to tint the front windscreen at all........ a sunstrip is allowed but can only cover a small percentage of the screen (cant remember the actual measurement) but it cannot infringe on the arc made by the windscreen wipers (some people put smaller wipers on to get around this but this is also technically illegal).
So, what could happen if you flout the law?
a) You run the risk of being stopped and fined – you are basically handing the police a ‘reason’ to stop your vehicle. Who knows what they might find then, giving them a reason to impound the car if it is considered dangerous to drive and/or could be given a prohobition order until removed!
b) You will be required to remove the window tinting film (at cost) and present your car to the Police to show them that it has been returned to a legal status.
c) If you have an accident and it can be proven that the reduced vision caused by the illegal film was a contributing factor, you are likely to get part or full blame – even if it was not under normal circumstances your fault!
d) Even worse – your insurer – if they stand to be in a position where they are looking at full acceptance of liability (as you were at fault) – may determine that your insurance is invalidated! and you will be looking at footing the costs on your own for your own vehicle and any other damage to third party vehicles or property.
Be warned - having tinted car windows might look great – and you may get away with it – but is it worth the risk?
Old 11th November 2011, 08:03 AM
That bit sounds unrealistic. The wipers on my S8 go right over the sunstrip built in to the windscreen and almost to the top of the glass on the outside; overlap is about 4" to 5"!
Old 15th December 2011, 08:47 AM
Originally Posted by Night Train View Post
This is an issue that's always intrigued me as a motorcyclist.... I'm not allowed to use a dark tinted visor, which I can easily flip up if neccessary, but can wear dark sunglasses inside the crash helmet, that are effectively non removable !
"94 At night or in poor visibility, do not use tinted glasses, lenses or visors if they restrict your vision."
Have they softened the rule? My Father always complains about this, but when I was looking in the latest Highway Code for something else, I spotted this above...
Old 15th December 2011, 09:04 AM
for once the law makes sense here
its true that as a biker during the day you could wear sunglasses and there wouldnt be any difference, but with a visor tinted it would leave you with bad vision at night or having the visor always up, same for a car we can wear sunglasses but they are removable at night wheras the tints are not.
I would rather the car had the same tint all round but safety first!. I am supprised no one has invented darkened one way tints that let the light in as per normal but look dark from the outside, could still cut out harmfull UV light and would allow the car to have darkened look all over
would probably get stopped everyday though
Old 15th December 2011, 06:16 PM
is this a proposal for "SnapDragon's Den" ?
