Old 28th March 2015, 01:11 PM
RanjS8 RanjS8 is offline
Default aircon drains
Hey guys how do i get aircon drains. How do i unblock them.
Ranj
Old 5th April 2015, 10:59 PM
Burnzybubbles's Avatar
They go through the trans tunnel by the centre console, you need to lift up the carpet and a bit of the centre consol trim and you'll see two angled rubber boots these need something poking up into the dash and out through the tunnel.
Old 8th April 2015, 08:24 AM
Ranj
If you run a search than you'll fine some very detailed write ups on this (I'll have a look when I get a moment), but the current wisdom seems to be that you remove the carpet/trim panel from each side of the transmission tunnel and then remove the drain tubes (they're orange) and wash them out.
Poking stuff up the tubes is likely to damage them (as I think Brian found out the hard way!).
Old 8th April 2015, 08:35 AM
Jim, that's D2, not sure if D3 is the same......
Old 8th April 2015, 08:57 AM
So what car do you have Ranj? Everything in your signature has "gone to a new home"!
Old 8th April 2015, 09:01 AM
D3's are the same, I was suffering water ingress so checked my aircon drians as first port of call.
