Old 22nd January 2009, 11:51 AM
JONAMAT
Guest
Posts: n/a
Default Radio data display.
As a previous and grateful customer, I think it is great to have this new forum..thanks Ian.
1996 D2. 4.2Q. The radio is failing to shown details on the instrument panel.
The panel works fine on everything else and the top section operates on warnings etc so I assume it to be OK. Have checked wiring and data plugs etc but no success. Is this a common fault ? Is the radio likely to be the problem? This is not crucial, it's just nice to have evrything working.
Old 22nd January 2009, 12:28 PM
Originally Posted by JONAMAT View Post
As a previous an grateful customer, I think it is great to have this forum..thanks Ian.
Hi there, great to see you on board.
In 1996 you will have a Delta head unit no doubt, and the DIS (driver information system) display has always been pretty reliable with them.
The attached photo shows the back of a headunit. There is a multicoloured block connector with a green, blue and yellow connector. The middle connector has the connections for DIS and I'd probably start by rechecking these as they would be the most likely culprit.
This aside, you're looking at a coding problem with the instrument cluster (unlikely as I cant see anyone would have fiddled with it) or a faulty instrument cluster / head unit.
Old 22nd January 2009, 08:41 PM
JONAMAT
Guest
Posts: n/a
Thanks for that..I will have the radio out at the week-end.
