Oil pick up pipe in the sump
has anyone removed the sump and checked /cleaned the oil pick up pipe gauze and if so is there anything else that should be done when in there and would you have the torque setting for the sump and pick up ,i've check but can't find
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
I found the following settings for the sump bolts, which I've reproduced exactly (as I don't understand the difference):
Sump (Lower bolt(s)) Stage 1 - 5Nm Stage 2 - 9Nm Sump (Upper bolt(s)) Stage 1 - 5Nm Stage 2 - 90 degrees Can't find anything for the pickup. While you're at that end of the engine, the oil drain plug is 25Nm. Obvious question (for MJ) as I've never dealt with sump bolts before, but are those values so low because of the thinness of the metal used for the sump, to avoid distortion?
The 5+90° is the same as the cam caps in the D2. They're trying to achieve a specific amount of tension on the bolt with the 90°, as an angle is more accurate than a turning torque. Usually an angle signifies the bolt is torque-to-yield (stretching past its elastic limit) but that spec isn't enough to stretch a high tensile M6 bolt (I've measured used against new) so its just done for accurate tension. Last edited by MikkiJayne; 5th February 2021 at 01:57 PM. |
Thanks Sean and mj,i'll let you know who it goes
Paul Gosport UK ________________________ Audi S8 2002 FE Avus Silver / Extended Red Leather. Daily Driver: BMW 3 series GT - Just more practical for my camping trips! |
The torque settings being referenced in the post are for the 5.2 V10 engine.
Sump of and all looks good ,the gauze look to be perfectly clean ,i removed the arb to get acess to the row of rear bolts and it made it straightforward
Ps the metal pipe in the pic is attached to the bottom of the rad with 2 screws ,and it's very badly corroded at one point does anyone know part no or have exploded diagram for it please
11-Service Manual 10-cylinder direct petrol injection engine (5 2 ltr 4-valve BSM) mechanics.pdf
It's called the bottom front coolant pipe in the 3rd pic down Sean ,i'll have another look to see if I can find a better diagram with it
