Old 26th January 2021, 10:22 PM
S81 S81 is offline
Default Air inlet manifold
I'm removing the inlet manifold to check carbon and replace oil filter seals ,and I've noticed the inside of the inlet manifold has an oily ness about it ,is this normal or do i have a problem with the oil separator ,(84k miles ) the flaps look ok to me but I would like to operate them to be sure when I get it on the bench ,is it possible to do this without damaging them ? ,ps should i clean inside with a degreaser and hot water or better to leave it alone
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 27th January 2021, 03:29 PM
kele kele is offline
It is normal for some fuel and oil vapor and gas to go in there. I have fitted catch cans on each side now (after fitting a brand new intake). Those cans do collect some fuel and oil ahead of the PCV. In the hope that carbon build up is reduced...
2022 Mercedes EQC 400
2008 A8 3.0 Tdi sport, B&O
Old 27th January 2021, 06:22 PM
S81 S81 is offline
Thanks if you get a chance could you send me a pic of cans so that I can see were to fit and the make and model of them please
Daily driver
Previously owned
Old 30th January 2021, 09:40 PM
S81 S81 is offline
I noticed when I was carbon cleaning that the valve ports closest to the bulkhead had very little carbon were as the ones near the rad had a lot ,i'm guessing this has something to do with airflow ,(i didn't think to get a pic of the bulkhead ones that's the front ones )
Daily driver
Previously owned
Old 6th February 2021, 03:41 PM
S81 S81 is offline
Sean would you have had the torque setting for the inlet manifold ,o checked the tech sections and threads but either have missed it or can't find them ,i have manifold cleaned and checked and back in just need to torque it down before refiting fuel pipe pumps etc
Daily driver
Previously owned
Old 6th February 2021, 06:40 PM
homer simpson's Avatar
This should help
Old 6th February 2021, 06:42 PM
S81 S81 is offline
That's it thanks
Daily driver
Previously owned
Old 6th February 2021, 08:13 PM
S81 S81 is offline
Manifold back on without any trouble,and torqued down thanks to homer ,couldn't get the drivers side rear fuel pipe tightened due to lack of space ,i'm thinking i should have tighten it before i put manifold in and tightened it ,will have to have an another look ( unless someone has a trick)
ID:	25462   Click image for larger version
Daily driver
Previously owned
Old 7th February 2021, 11:58 AM
I saw your request yesterday but since homer had already responded, never thought anymore about it. Now seeing this comment, I wish I had thought more about it, as I had the same issue with the rear passenger side. The previous owner had fitted a new manifold at around 100k and during spirited driving you'd get the smell of petrol fumes. New owner was informed about it and when checked it was because the pipe hadn't been tightened enough. Unfortunately I can't offer any advice on a solution.
Old 7th February 2021, 12:17 PM
S81 S81 is offline
I'm going to try a basin spanner to see if it works ,there is enough room down in there but a lot of obstacles above and around it ,
Daily driver
Previously owned
