Go Back   A8 Parts Forum > A8 D4 > D4 - Transmission
D4 - Transmission Gearboxes, diffs, drive shafts.
Old 1st August 2014, 10:51 AM
Stevie Stevie is offline
Default Gearbox Oil Change...
Ok, I'm going for my first major service at 38K miles. I went to a local independant.
Got a quote for a Major Service £345 + £210 for gearbox oil change.
Independant rings back and says Gearbox oil never has to be changed according to Audi. If you want it done its £403, not £210. I'll do it if you want, but you don't need to.
So comments please on this issue. I know its a definate for D3's wondering if things have changed for D4's - Should I go for it anyway?
Old 1st August 2014, 11:04 AM
You will see that most of people will recommend to get it done but to get it done at ZF automatic gearbox specialist.
Old 1st August 2014, 11:14 AM
You'll be on Lifeguard 8 oil.. It's about twice the price of the lifeguard 6 and 3 times the lifeguard 4. I'd take it to a proper ZF specialist.
Old 1st August 2014, 11:53 AM
sarg sarg is offline
That he is quoting you, then changing the quote, then telling you it doesn't need it, all of that would make me want to find an alternative indy.
As Richard says above, a ZF specialist would be best for the gearbox, the service can stay with an Audi specialist.
I've no doubt that Audi's 'official' schedules do not include a gearbox service, but their intepretation of "lifetime" is about 5 years/100,000 miles (i.e. if it fails after that then what do you expect, one that will last a lifetime???), so probably quite different from the rest of us.
Mercedes used to say sealed for life too, they changed about 2 years ago and are now including gearbox oil changes on their servicing, and have even retro-added it to the service-inclusive deals they sold at no extra charge.
If you've seen the oil come out of a 100k plus miler gearbox that's never been changed, you'll understand why it should be done, about every 40k I'd reckon
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 1st August 2014, 01:57 PM
I with you on this one....
So need to find a ZF specialist in the Midlands / East or West
Old 1st August 2014, 03:23 PM
Gearbox is a ZF8HP55 http://en.wikipedia.org/wiki/ZF_8HP_transmission
Old 2nd August 2014, 02:50 AM
In the Midlands, for servicing, though I've never used them myself, MRC Tuning in Banbury have a very good reputation
http://www.mrctuning.com/index.php/servicing/
I have used http://www.rsdlimited.com/ for servicing and MOTs, they are okay and were a big help when I had to replace my D2 steering rack a few years back. Not perfect, but okay.
For transmissions, the nearest recognised specialist is in Chester
http://www.transcentre.co.uk/
List of ZF Agents here:
http://www.zf.com/eu/content/en/grea...e_cars_uk.html
You should also read up here:
http://forum.a8parts.co.uk/showthread.php?t=24
and here:
http://forum.a8parts.co.uk/showthread.php?t=8
and here:
http://forum.a8parts.co.uk/showthread.php?t=122
and here:
http://forum.a8parts.co.uk/showthread.php?t=4060&page=5
Old 10th August 2014, 11:02 AM
ZF say this and I have seen silimar in on ELSA:
6- and 8-speed automatic transmissions:
ZF 6- and 8-speed transmissions are filled maintenance-free with specially developed partially synthetic ATF oils. Maintenance-free fills are intended for normal operating conditions. Especially driving at very high operating temperatures can result in accelerated aging or increased wear of ATF oils. It is recommended, in the event of severe operating conditions, such as:
- frequent highway driving in top speed range,
- offensive, sporty driving style,
- frequent trailer operation,
being above average, oil purification (oil change) on automatic transmissions is recommended between 80,000 km and 120,000 km, or 8 years, depending on the load. In each case, only released ATF oil may be used for oil changes. And oil changes must be performed in accordance with the relevant specifications.
I think with the cost of repairs being high, it is prudent to change the fluid every 2 or 3 years.
