Old 11th July 2010, 11:26 PM
carrotchomper carrotchomper is offline
Default What's the spec of an OEM battery?
IE cranking power and amps? They seem to compare based on CCA and amps... Need to probably buy a replacement tomorrow and there is a vast price difference between OEM, Varta and then the other makes. If there's not much in it I will get a cheapy.
Basically, the battery on my A8 is, I think, on it's way out. Prior to me buying it last March the car had been sat up for 3-4 months and the battery wasn't in the best of health, however it hasn't caused problems since.
On Friday I popped to shops en route to Wilts and sat outside with the blowers etc on for a bit too long- car wouldn't start! However luckily I was about 100m from Bristol Audi who very kindly sent a tech over with a battery pack.
Car made it to Wiltshire with no problems, however when I re-started for the second time the battery flattened itself again- clock and nav plus reset but it just started. Obviously with the blowers on and other gadgets it doesn't get much of a chance to re-charge however I think the battery's had a good innings now!
ETA- Having just checked the previous owner's records he fitted a Halfords battery in Sept 2006- 4 years sounds alright?!
Old 12th July 2010, 05:10 PM
For future reference, it's an 88amp 017 battery you need. Decided against the Audi OEN battery as it was £144 and ended up with an equivalent Numax battery with a 3yr warranty.
Car is so much more lively starting! Old battery was obviously well under par.
Old 12th July 2010, 07:49 PM
I went for the posh Bosch one with a 5 year warranty, its £115 from Halfords but I can get it for £90 for anyone in Leamington as can get trade. Or cheaper Halfords ones dirt cheap too.
Old 13th July 2010, 03:45 PM
The posh one seems to be £130 from Halfords online now, the only other alternative from them is over £100 as far as I can see. The Numax seemed to be a fairly standard price- Purchased from a local motor factor for £83 inc VAT.
Old 11th October 2010, 01:14 PM
GlynH GlynH is offline
I also have a requirement for a new battery as i have had to charge mine twice in a week which doesn't bode well especially as winter is coming.
If anyone has the part number for the original Audi battery it would be appreciated as I might be able to get one at a discount if only I knew what part number to order!
For reference the one fitted to the car is marked as follows;
Hoppecke
441 915 105
12v 450A 92Ah
Would that be the original battery I wonder as it looks like it could be German?
Failing that I did see the silver coloured Bosch battery in Halfords that I assume has been referred in this thread?
Would this, or another 3rd party battery be a better choice than the OEM fit and if so why?
End of questions!
Thanks & kind regards,
-=Glyn=-
Old 11th October 2010, 04:27 PM
I think it's an 019, 100ah. Same battery used in Jag XJ's, DB9's and Derv Merc Sprinter van is where i got mine from.
The OEM was probably a Varta if you look in the recess where the terminals are the vw and audi rings should be stamped in there.
Old 18th October 2010, 04:47 PM
The Audi part number for the battery looks to be 000915105DK if that might be of help to anybody?
-=Glyn=-
