#31
Thanks for that.
I did go through the whole motor/caliper question but it's due a brake fluid change so I'll end up swapping the unit out as a whole. What I will do though is use an electrical sealant grease around the seal to try and futureproof the repair. Between the sat nav aerial on the D4 and the PB motors on the D3, Audi have taken their eye off of the ball on the whole waterproofing front!
1988 Audi 90 2.2E 2011 Mercedes E250 2016 Abarth 595 Competizione 2012 Porsche 981 3.4S PDK mid life crisis! |
#32
Problem solved, new caliper on the offside, working motor from there transferred back to the nearside, recalibrated and seems fine. It was meant to be an exchange caliper but it's split new and came in a TRW box complete with bolts, shims etc. and prefilled with fluid. We'll see how long this one lasts! Well done Murray's
#33
I have skipped to the end of this thread, but I had the same issue and it turned out to be the EPB ECU that lives in the boot under the battery, I changed this and instant relief from the symphony of beeps
#34
I ruled that out by switching the parking brake motors over and the fault transferred with it so definitely not that on this occasion
#35
Must be something in the air - On the motorway today, I had a beep and the small EPB warning. I thought :-why now ? I am not using it- and carried on so I could do VCDS at home.
I stopped off 100 miles later and set off again and later a lorry started to flash me. One of the rear brakes was smoking. I thanked him and pulled over and got out and the drivers brake was very hot. I asked the wife to cycle the EPB and it was making the usual noise but came up with the big full DIS error. Kept cycling it and seemed free so drove home slowly. When I got home it was not that hot and VCDS had 3 errors as at the bottom. If the weather's fine at the weekend, I'll check the connectors again and remove them and grease them up and hope for the best. ... Thursday,26,February,2015,18:23:47:22166 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 15.2.0.0 (x64) Data version: 20150130 --------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Control Module Part Number: 4E0 910 801 D HW: 4E0 907 801 B Component and/or Version: EPB A4EC0230 H03 0230 Software Coding: 0000221 Work Shop Code: WSC 00097 210 194805 VCID: 20446925F395753843-8075 3 Faults Found: 02443 - Control Head 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00110011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 206 Mileage: 336952 km Time Indication: 0 Date: 2015.02.26 Time: 16:41:12 Freeze Frame: Voltage: 12.63 V Count: 49 01487 - System Function Test 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 206 Mileage: 336952 km Time Indication: 0 Date: 2015.02.26 Time: 16:32:36 Freeze Frame: Voltage: 12.63 V Count: 160 02434 - Supply Voltage for Control Module for Left Channel 006 - Short to Plus - MIL ON Freeze Frame: Fault Status: 11110110 Fault Priority: 1 Fault Frequency: 2 Reset counter: 166 Mileage: 336776 km Time Indication: 0 Date: 2015.02.26 Time: 14:09:51 Freeze Frame: Voltage: 12.63 V Count: 110 Last edited by snapdragon; 26th February 2015 at 07:02 PM. |
#36
And now the nearside one has gone!
Certainly predictable enough I suppose as it had the same cracking to the plastic cover that the offside did. Had to pop the fuses on this one though as the ECU thought it was stuck on (it wasn't, it had failed in the open position). Vexing, terribly, terrible vexing! An easy fix though.
