Old 18th June 2011, 09:24 AM
LOL!
Need an RNS-E first - and I know Serge is working on getting the diplay in the instrument cluster to work with an RNS-E.....the only reason I've not fitted one yet
Old 18th June 2011, 10:03 AM
Same here Jim and I know Mike has the same view . . . sooo . . . no pressure Sergey! lol
Old 18th June 2011, 11:47 AM
Can you not still fit an Aux-in to RNS-D?
Old 30th July 2011, 10:27 AM
GlynH GlynH is offline
He is?
Am I understanding this correctly...we are talking about the RNS-E SatNav instructions back in the DIS?
If you do this Sergey you will become a God in my eyes!
I delayed my own D->E upgrade for a while because I did not want to be without the SatNav instructions in the DIS but relented in the end and never regretted it because the E is so much better than the D all-round.
All of the other messages from the E make it to the DIS including phone/radio/cd/tv/mp3 info etc. etc...only the SatNav info appears to be missing.
I know other '8 Gods' such as CraigyB, PaulW and Bjarne with his CANGate etc. were looking into this years ago but it got highly complex and due to the lack of a resolution I believe was given up on...real pity.
If we could get SatNav info back into the DIS then that would be one hell of a result.
Good luck Sergey...if there's anything I can do to help just let me know!
Regards,
-=Glyn=-
Originally Posted by IceBlue8 View Post
LOL!
Old 12th August 2012, 05:25 PM
71camaro 71camaro is offline
Bringing this back up, OP, if ypu could detail this install I'd be appreciative!
Old 12th August 2012, 06:26 PM
Camaro, I'm sorry to say Aux input only works for European RNS-E firmware.
US RNS-E firmware doesn't support aux input.
Old 12th August 2012, 06:36 PM
Hmmmm, I'm not sure that's completely right, I've seen a number of US cars with AUX cables run from the RNS-E here in the States, but I like this as it's a much cleaner look than what I've seen before. This almost looks OEM, which is my preference.
Upon looking a bit more, firmware update SW260 is required on the unit.
Old 12th August 2012, 10:16 PM
Maybe Audi released newer firmware for US that supports Aux input.
You need to connect 3 pins. Easy to find in google.
The +5V USB charger is done by hiding Belkin portable USB charger behind cover. It basically coverts ignition controlled +12V to +5V. I have purchased aftermarket cigarette lighter female socket, connected it to ignition controlled +12V, then inserted USB cable in it, and connected that cable to the back of BMW socket. All needed BMW parts are specified in photograph of invoice.
Old 12th August 2012, 10:21 PM
Adaper i used behind the scene:
http://www.belkin.com/IWCatProductPa...duct_Id=489767
It provides 1000mA cureent, which makes it possible to charge iPhone with standard Apple USB cable.
Old 13th August 2012, 05:00 PM
Aux input installation:
http://www.audizine.com/forum/showth...UX-RNS-E-(pics)
