Water drips from boot light cluster
I'm trying to work out exactly what's going on, but whenever I open the boot some time after rain water drips from the outer edge of the light cluster into the boot.
It's more annoying than anything, there's not a huge amount and it's not coming from inside the lights as far as I can see. I "think" the seal around the light cluster is somewhat porous and water I soaking in there, probably assisted by a build-up of absorbent debris. Then when I open the boot it just runs out at the edge. But I'm reluctant to go "excavating" until I understand what's supposed to be there. It may be that just carefully cleaning out muck and applying some water repellent will be adequate, or maybe a little bit of black silicone filler. Does anyone have a close-up picture of what those seals are like, or at least describe them? Thanks in advance.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Andrew, I have a pair of boot light clusters in my spares box. (ex-Mr Blobby). If you tell me exactly what it is you want to see I can take some photos.
Thanks David, but it's how they seal to the boot lid I'm after, so off the car in a box is unlikely to help.
Unless they have the seals around them, in which case a close up of the bottom edge and bottom outer corner showing where the seals are?
The rubber seals are attached to the light cluster. Ill upload some photos .
I think that these show what you want? The seal, as you can see, is a fairly substantial rubber seal. The lower strip is, however, prone to dirt build up and is rough and possibly the point of water entry.
Excellent David, exactly what I needed to know.
Didn't realise the seals were so deep. I'll carefully clean out as much crud as I can and see what happens. After that I'll try a bit of silicone lubricant/water repellent then if all else fails a black silicone "top-up" or mastic. I'm reluctant to take them out and risk damaging a seal that's currently reasonably intact.
