Old 31st July 2012, 08:38 PM
Or a USB PCI card, should be cheap.
Old 31st July 2012, 09:32 PM
RanjS8 RanjS8 is offline
Default Pci card
I would love to put a pci card in but when I tried to open the case it was bolted in by these security type bolts which have a triangular head???? The first time i have seen these...
The hp laserjets seem pretty cheap, but it is a pentium computer with dare I say it possibly even window 3.x operating system....so i'm wondering if the computer will be able to use it.....
Old 31st July 2012, 09:33 PM
Better bet than a USB/Parallel adapter, that will only work on later systems.
As for security bolts, if you can get the head off a V8 that's hardly a challenge!
As for HP Laserjets, they've been around longer than most versions of Windows. Get a Laserjet III from 1990 or so or a Laserjet II from the 1980's ...
Old 31st July 2012, 09:38 PM
Default Security bolts
Tell my mother that...she relies on that computer for her business and she is worried it will end up in bits like this s8 and take me months to put it back together again...lol
Old 31st July 2012, 11:05 PM
sarg sarg is offline
Gas meter box key?
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 1st August 2012, 05:32 AM
Can't go wrong with cheap Laserjet just get one with ethernet port so that you can hook it up to network and use from several computers. The one I have does have it and it's hooked up to network and with £25 cartridge for 11k copies, it's really cheap to use as well. It needs servicing at 300k copies but mine has only done 49k since it was new in 2003. I probably printed out only 2-3k in last 4 years so it will last another 100 years.
Old 1st August 2012, 07:42 AM
Maplin do the security bits for screwdrivers....
Old 1st August 2012, 07:48 AM
Yes, but if it's a really old system USB support or printer drivers may be an issue, so no point opening it.
Best to get a compatible parallel printer, known to have drivers for the OS.
What version of Windows is it?
Old 1st August 2012, 02:46 PM
Reffro Reffro is offline
I have an old laser printer sat on the floor at home, I'll send you the model number tonight and you can have it if you want. Its an old one my sister used to use for work.
Old 1st August 2012, 09:25 PM
Default Thanks Reffro
Thanks Reffro I ll take you up on the offer as in the very least I can check if it will work...which I m sure it will.
