P3028 - 008 - Implausible Signal
Where do I start......
I've been a bit quiet the last few months as I've been quite overwhelmed with work and the majority of my cars all having niggling, expensive and hard to diagnose faults. Both my v10's have been off the road now for most of this year and I was really getting to the end of my tether with it all to be honest. But this post is a positive one, as I seem to have a solution for a problem that is so far undocumented anywhere in the known universe, and my god have I googled the **** off it So, a 2010 RS6. Remapped, and with Miltek to add a little extra complication, and had a large number of other niggles, and poor tyres and worn brakes and basically it was a blown fuse short of a write off some weekends I'll tell you. It drove almost perfectly when I got it. Very hard to fault it, but due to a large number of other issues to deal with, it spent a lot of time sat and at some point it just became obvious that it was very not right. The symptoms were simple. Drive it like a saint and all seemed well. Drive it like an RS6 and it would crap out at the most inopportune moment, ESP/engine warning lights, limp mode, violent deceleration and you basically look like a knob in an Audi who can't manage to overtake a fiesta successfully. The error that was a constant was: 012328 - Angle Sensor 2 for Throttle Drive 2 (G298) P3028 - 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 108134 km Time Indication: 0 Date: 2017.07.25 Time: 15:22:42 Freeze Frame: RPM: 5061 /min Load: 14.1 % Speed: 81.0 km/h Temperature: 82.0°C Temperature: 50.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.335 V Ignition off and back on, and all was sweet again. Until you put the throttle down. Every single piece of advice under the sun will tell you to change the £1000 throttle bodies. Or clean them. Or do a rain dance around them. Or polish them or basically just keep messing with them indefinitely until it works. Ignore it. The throttle bodies are perfect. All 5 of the ones I fitted over the time... I spent countless weekends driving like a fairy for 20 mins to warm it up, then like a pillock trying to figure out what the actual root trigger was. And about a month ago, I nailed it. Reproduced it time and time and time again. I was so happy, in a weird way. I found I could drive any way I wanted in 3rd, 4th, 5th and 6th gear - but - in 1st or second hard boost over ~3500 rpm and it would crap out. Every single time. It is no co-incidence that this is the time that the throttle bodies are moving their fastest to alter the inbound flow of air. In every other gear, the revs build a bit slower, so no sudden swing. The throttle bodies (2 of, 1 per bank) are the simplest contraptions ever. They have 6 wires. 2 wires are DC voltage to the flap motor that moves the flap backwards and forward to increase/decrease air. Then, there are 2 pairs of wires. Each pair goes to a position sensor, exactly like the accelerator pedal. One sensor reads high and reduces with movement. One sensor reads low and increases with movement, hence the sum of both sensors must be same give or take a particular tolerance. So, if its complaining at the readings, lets see the readings. Here is a good working example from ECU1, reading throttle body 1 using vagcom on turbo mode. You can see when the throttle is blipped the sensor readings invert with perfect precision. Now, look at the graph for ECU 2: So, circled in yellow is the problem. They simply don't match. The ECU thinks that the value is considerably different to the other sensor, and freaks out.... Now, if that wasn't weird enough. Check out this graph. Sorry for the noise, but look at the pink and brown lines. According the ECU, the value is over 100%... wtf. So its reading more voltage in, than its sending out. huh ? At this point, I struck up conversation with Doug at MRC as I was trying to understand if the remap in any way could affect the measuring blocks. I wasn't sure what response to expect from my detailed DIY self diagnosis email as I'm sure they're busy guys, but to their credit he engaged with me and suggested as throttle bodies had been changed, first port of call was to swap out the ECU just to make sure. Its worth knowing that MRC can clone ECU's, so forget key coding and immobilisers and all that jazz, they just hoover the entire config and blat it over. Very handy. Before that though, Doug had spotted that the signal on sensor 2 showed irregularities on idle. This was another major breakthrough as no longer did it have to be warmed up and then driven quickly to diagnose. This was the car wobbling a bit on idle at their workshop: Good, easy to reproduce, but sadly the ECU swap made no difference. On the plus side, @ £1500 i was sort of glad tbh. I had personally changed both throttle bodies. Cleaned them. Stripped them and cleaned them. Swapped the sides over, and then Doug also swapped them over again to rule it out, but never, ever did the fault move. So, the final, and least likely culprit is the wiring. Its a perfectly intact, unmolested beautifully looking loom, so it made no sense - but - I did find that the VW Tourag had an Technical Service Bulletin out regarding a similar issue that suggested that the connector on the Throttle body, having only 6 wires, was prone to a bit of movement and could over time cause problems. I had previously questioned Audi on TSB's for the V10. Nothing. Spoken to independent Audi specialist, not ever heard of a V10 issue. It was new to MRC also, and to suggest changing the 6 pin plug and the wires back towards the ECU seemed rather odd, but having literally eliminated everything else I authorised the works. A few days later I got another screenshot: It seems fixed came the message, but as they'd also serviced it and found the inner edges of the front tyres to be bald they could no longer road test it. Aargh. How frustrating So, Finally, today got it trailered home and I am abso-fecking-lotely chuffed to report it is now spot on..... I thought it would be, but the proof was in the pudding. Interesting it had a dyno session whilst it was there and posted up virtually identical numbers to 3 years ago, which was a bloody good sign. Its also drives a bit smoother, and the exhaust doesn't pop quite as much as presumably the fuel/air mix is now spot on. I'd say gear changes are even sweeter too........ Hurrah. So, quite a trek to drop it off at MRC but it was worth the effort. Now for a set of new brakes and an MOT and we're about there on this one. ..... I now have a full 750 bhp just in time for winter. Oh goody....
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
So chuffed in fact that you forgot to include the images
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
No, sadly like everything else with this car, if it can go wrong it will.....
I didn't forget the images, I actually forgot to submit the post.... I realised many hours later and almost unbelievably, did enough 'backs' on Internet Explorer to find the last preview I had, and was able to submit it..... but my laptop had cached the images so didn't realise it had lost the photos... !
More than once I've gone back to look for something I'd posted and ended up convinced that the forum had "lost" it. Eventually realising that I'd just never actually posted it in the first place! Though the way Microsoft software works does make such slips easier.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Excellent. Love it when things get sorted, especially the annoyingly (possibly) expensive kind.
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
Things that spring to my (relatively inexperienced) mind would be: - Contamination/corrosion in the connector(s) that mate to the throttle body. - Wear/looseness in these connectors. - Poor contact between the cable core and the connector due to manufacturing problems or wear. - Connector insecure in the plug body. - Failure in a cable core. I'm sure there are other things to look for as well.
On another note, how did you decide to remedy the brake situation?
Del |
The 'cheapest' I've managed to source a full set of ceramics is about £6500. There is also some doubt how bad the front ones are. Audi say they're due, MRC say they look ok. Until I get them off and weigh them I won't really know. Ceramics look dam pretty, but for my driving style, I just don't need them, and ultimately for resale, I wonder if having ceramics puts people off so it seems almost certain steels the route that will be taken......
My strong suspicion is that the cable core had a number of frayed strands where it 90 degree bends towards the throttle body. The connectors and pins had been thoroughly inspected and cleaned several times....
