Old 26th August 2014, 01:55 PM
roboblob roboblob is offline
Anyone know where the earth point G43 is in the cabin , it says its above right kick panel but is it the same for a RHD car since we have our relay box in the passenger side not the drivers side ?
Old 28th August 2014, 01:58 PM
Not a clue, but did you manage to find and clean up the earth in the wheel arch? And what brought up the G43 earth point?
Old 28th August 2014, 02:39 PM
Electrician has been out , it looks like its the ignition side that's breaking down rather than the earth, he managed to get display to work correctly by shorting out in the relay box, he wanted to take car over to his garage so he could remove airbag and wheel to check the switch further, incase he needs to trace to the fuse box.
So I have ordered a new switch , surely that can be replaced without taking off the wheel.
After reading I see it cant, looks easy enough I will try replacing the switch myself first
Old 28th August 2014, 06:00 PM
all fixed
turned out ignition cable was not seated into switch properly, one click later and I has v8 power again yippee!!!!!
Old 29th August 2014, 06:30 AM
Great news!
