My money is on a faulty pump or corroded wiring/plug due to the water leak.
I've just had exactly this fault on my D2 and it was an item causing the pump to stick ie the impeller pump jammed. once free its back to working fine
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
To update this, the fuses were all OK, as was the connection.
I stripped out the wheel arch liner and found the little black motor had some corrosion at one end and had seized, I also believe that's where the leak was coming from and how the tank emptied itself every now and again. Replaced with a new motor and it now works as it should. Also took the opportunity to clear out the little plastic mesh filter which was full of lovely Legionnaires' with some hot soapy water. From what I remember when I had it apart, there is another motor for the headlamp washers, just a bit further up in the tank. I can't find a diagram for it on ETKA but does anybody know if it's an identical motor to the windscreen one? If so I'll order another and change that too for peace of mind.
Currently '8-less Previously: - Aqua Blue Pearl D3 S8 - Kamut Beige leather, ACC, B&O, factory RSE, solar sunroof, electric blinds, ski bag, Homelink, comfort headrests. - Aqua Blue D2 S8 - Grey leather/Alcantara - D3 A8 3.0 CVT - D3 3.7 V8 |
Glad to hear you got it sorted. Was the motor expensive?
I cleaned mine out and it's now working well, but I'd like to be prepared in case it needs changing in future. I think I removed the motors and they looked different, but my memory is vague so I may be wrong. |
Think they are £55 for a genuine one from Audi, or £20 from Eurocarparts.
Once the wheel is off and wheel arch liner is peeled back, you'll see how it all works and exactly where the motors are. They're dead easy to take out and swap but be warned, whatever is in the tank will all just trickle out unless you bung the temporary hole with something.
The D2 one is a bit of a bitch to fit as it is held hostage by the Headlight, Bumper, Bracket and Air Box etc but can be wiggled out with a lot of faffing (fortunately not by me lol)
Windscreen washer is (9) 1K5 995 651 - also use 1J0 995 665 H Headlamp washer (10) 3D0 955 681 |
