Old 6th November 2017, 05:54 PM
Default 17953 - Throttle Valve Controller Malfunction
Hi All,
As above, here are the log details.
Does anyone have any ideas?
P1545 - 002 - Malfunction
Freeze Frame:
RPM: 756 /min
Torque: 35.1 Nm
Speed: 0.0 km/h
Voltage: 14.44 V
Duty Cycle: 24.1 %
Bin. Bits: 000
Mass Air / Rev.: 364.3 mg/str
Voltage: 0.000 V
Or can I ignore it?
Old 12th November 2017, 09:06 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Hi Ray.
Do you have any warning lights or issues when you stop the engine, keeps running for instance? Fault appeared to happen at idle.
I believe it’s something related to plastic cogs that wear, inside the throttle body. But I’m no mechanic.
2007 Mini Cooper S R56
