Old 13th March 2016, 07:48 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Dpf?
Hi all.
Just recently bought oil to change it myself. Went for the 507 for lower ash etc etc, because the 3.0 TDi 2008 may have a DPF. 2008 Listings for the car seem to have DPF and non DPF versions, the online ones.
I could not find a definitive yes or no, as to whether the car has a DPF or not. I haven't seen a DPF warning light ever light up, at start up or otherwise.
So, can anyone tell me either way, and satisfy my curiosity?
All the best
John.
2007 Mini Cooper S R56
Old 15th March 2016, 02:40 PM
Hi all.
All the best
John.
Looks like the only way is to check the PR codes for your car.
My 2004 [MY 2005] A8 has "PR-7GN", which is "Emissions concept. EU4, DPF preparation" which I take to mean "we've put some stuff in the car ready but haven't put the DPF in"!!
I believe VAG group cars all use the 7Xy code [where X is a letter] to indicate which prep is installed.
Regards - Julian
Old 15th March 2016, 02:58 PM
Johnmed's Avatar
Regards - Julian
Cheers Julian. I'll have a look at the sticker near the spare wheel.
Old 15th March 2016, 07:21 PM
Default VAG PR-7xx codes for emissions ...
I found my codes in the front of the Service book.
Here are the VAG codes I'm aware of:
7GA AGM Emission standard LEV 2
7GB AGM Emission standard ULEV 2
7GC AGM Emissions concept TIER1 for Mexico with OBD
7GD AGM Emission standard EU4 China without EOBDwith hardware modification
7GE AGM Emission standard EU4 for Japan
7GF AGM Emission standard EU3 without EOBD with hardware modification
7GG AGM Emission standard EU4 DPF
7GH AGM Emission standard EU4 without EOBD without hardware modification
7GJ AGM Emission standard TIER 2
7GK AGM Emission standard TIER2 for Mexico
7GL AGM Emission standard TIER1 for BR w/o OBD
7GM AGM Emission standard, EU3 without EOBD without hardware modification
7GN AGM Emission standard, EU4, DPF preparation
7GP AGM Emission standard TIER1 for BR with OBD
7GQ AGM Emission standard, EURO IV, DPF
7GR AGM Emission standard, C5 stage 2
7GT AGM Emission standard FTP 75
7GU AGM Emission standard MVEG 1
7GV AGM EPA TIER 3
7GW AGM BSO II
7GX AGM Marine 94/25 EG
7GY AGM Emission standard, appendix 25
7GZ AGM Emission standard not designated
Old 16th April 2016, 10:40 PM
Lee S Lee S is offline
Check the exhaust tips. Normally non-dpf cars have downward pointing exhaust tips that will be black and sooty and dpf equipped cars will have normal horizontal exiting exhaust tips that are so clean you could eat your dinner off them. As a general rule anyway....
Lee
2017 Nissan Leaf Tekna
Old 16th April 2016, 10:47 PM
Johnmed's Avatar
Cheers Lee. Mine are the clean horizontal types. Ha.
Old 17th April 2016, 06:44 AM
47p2's Avatar
47p2 47p2 is offline
2008 UK spec car will be fitted with DPF
Nite Blue 3.0L SE Quattro
Old 17th April 2016, 07:54 AM
Johnmed's Avatar
Cheers. I concluded as much. Essentially I just wanted to know which oil to buy, whether I needed the 507 lower ash oils.
Thanks chaps
Old 28th April 2016, 07:31 PM
There should also be an EU Emissions Regime sticker under the bonnet which will say EU4+DPF and that's why I'll be voting out on June 23rd.
Old 28th April 2016, 07:36 PM
Johnmed's Avatar
Ha ha ha.
