Old 24th February 2012, 01:38 PM
You are supposed to disconnect battery before touching anything airbag related and leave it for 10-15 min to let the capacitors drain out. This will prevent any mishaps and also there will be no fault code giving airbag light.
Old 24th February 2012, 06:16 PM
Dave1981 Dave1981 is offline
Thanks for the advise fellas i am very greatful.
Cheers Dave
Old 25th February 2012, 04:41 PM
Hi all I changed the cable today and it's still the same is there anything else I can do.
cheers Dave
Old 5th March 2012, 07:26 PM
Hi all I have changed the immobiliser box under the dash and now it's coming up with ecu fault so apart from changing the ecu I don't have anymore ideas.A new ecu is going to be over a £1000 from audis.
Anymore ideas that could help I would be very greatful.
Cheers Dave
Old 5th March 2012, 07:41 PM
PM mkoneman he should be able to help.
Old 5th March 2012, 07:48 PM
You know immo box need to be coded to ecu and keys, have you done it?
Old 5th March 2012, 08:17 PM
Yes it was coded mate.
Cheers Dave
Old 5th March 2012, 08:25 PM
What are the faults showing now? You should be able to get second hand ECU from A8parts:
http://stores.ebay.co.uk/A8parts/Eng...&_sid=37490737
Old 5th March 2012, 08:35 PM
I don't know 100% as yet as if only had a phone call about it I haven't been to see the car but as soon as I find out I will up date you all.
Cheers Dave
Old 5th March 2012, 09:55 PM
Dodgy fuel pump caused this on my D2
