Old 28th April 2016, 03:52 AM
mcs's Avatar
mcs mcs is offline
Originally Posted by A8Pete View Post
I'd like to give this a try. I have a couple of quick questions:
- I have a 2004 A8 D3 4.0 Diesel. Is this compatible with my car;
- Where is the aux input in the boot of the car and how is it wired in. I couldnt see it in your pictures
- can the music on my android phone be controlled from the MMI interface on the dashboard. I have a cd/tv button on the centre console, then I select AV from the source option on screen
Many thanks
Sorry I haven't logged in to look at this thread for a while so I will try and answer a few questions at once:
The sound quality is excellent. 9.5/10 compared to the AMI but not as good as a CD. Equivalent to Bluetooth streaming to your home cinema.
I have the AMI but I prefer not to use the Bluetooth streaming all the time and prefer to have an ipod plugged in all the time instead. So I wanted both. This means I went for the Fusion BT-100.
Anything connected to RCA cables in the car will NOT be able to be controlled by the MMI. You would need an AMI unit for that. Since the cost of this little receiver is tiny, I wouldn't expect MMI control anyway. Happily, both the Audi phone and Fusion BT connect simultaneously and do not interfere when music is playing or a phone call is on. The phone Siri can control the music so no need for the mmi control.
To fit this unit you will need:
An Analogue or digital TV module, which has inputs for the RCA. Since specs are all over the place in different countries, you need to check your car to find out if you have the TV module and then buy and fit the Kufatec RCA cables.
When the AV1 is selected the music comes through. The screen goes blank as I have nothing plugged into the video cable. I could easily fit something but I can't be bothered. I usually change it back to the CAR page on the MMI or NAV. The music plays as normal still.
Mike
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Old 29th April 2016, 02:51 PM
A8Pete A8Pete is offline
I have now received my AV cable. Is there a picture of the pins on the red plug that I need to connect into.
Many thanks
Old 29th April 2016, 07:02 PM
Here is what I posted in July 2015
I can confirm that the Aux Output gives a video/audio signal for the RSE(Rear Seat Entertainment). The output is whatever you have selected on the MMI.
I do not have RSE so I borrowed Guy's car and used a long RCA cable to send my Output to his Aux 1 input. Whatever I selected on my MMI was relayed to his MMI.
To save any misconception here are the pinouts tidied up:-
Aux Input 1
PIN 09 – Audio Shield left/right
PIN 10 – Audio signal left white
PIN 11 – Audio signal right red
PIN 12 – Video signal yellow
PIN 13 - Video Shield
Aux Input 2
PIN 15 – Audio Shield left/right
PIN 16 – Audio signal left white
PIN 17 – Audio signal right red
PIN 18 – Video signal yellow
PIN 19 – Video Shield
Video output (only for Hybrid-Tuner)
PIN 4 – Video Shield
PIN 5 – Video signal yellow
PIN 6 – Audio Shield left/right
PIN 7 – Audio left white
PIN 8 – Audio right red
Old 30th April 2016, 10:11 AM
Aux Input 1
Aux Input 2
Thank you very much. Could you just clarify the numbers of the pins on the physical 20 pin plug. So If I look from the rear of the plug on the side where the cables are inserted, which is pin 1, pin 2 etc so I know following guide above which pin goes where.
Many thanks
Old 30th April 2016, 10:18 AM
the connector is marked with the numbers on each corner.
Old 30th April 2016, 10:25 AM
http://www.audi-resource.com/retro-aux.php
Old 30th April 2016, 02:28 PM
I hadn't realised they were labelled on the connector. Right, off to the garage I go.......
Old 30th April 2016, 03:00 PM
Ok, all done. The AV1 lead is on. Only took about 10 minutes. My steps were:
1. Remove interior cover by turning the two plastic screws a quarter turn
2. reach in an unplug the red 20 pin connect. I didn't need to remove the nav player
3. Slide the red cover sideways off the 20 pin connector block
4. make a note of the pin numbers indicated in each corner of the block and then insert the pins on the AV fly lead as per the instructions earlier in this thread
5. Slide the red cover back onto the connector block
6. secure the leads with a tie wrap
And that was it. I just need to add an AV source and test it.
I attach a few pictures.
Thanks again to all for your help. Much appreciated.
Name:	av1-1 (Medium).jpg
ID:	13263   Click image for larger version
Name:	av1-2 (Medium).jpg
ID:	13264   Click image for larger version
Name:	av1-3 (Medium).jpg
ID:	13265   Click image for larger version
Name:	av1-4 (Medium).jpg
Old 30th April 2016, 06:45 PM
Well done.
Thanks for letting us know that all is well.
Great isn't it when it all goes together.
My holdup is readies, have to keep saving up for everything, and just as I think I'm nearly there Mrs management comes up with something urgent, like washing powder or toothpaste needed.
Old 30th April 2016, 10:25 PM
Well done.
Yes, I was pleased when it all worked! Just need to test it. Going to add a bluetooth dongle to the AV1 input and then pair it with my phone.
I tend to ask for forgiveness rather than permission
Thanks for your help
