Old 1st December 2020, 08:46 PM
Once again, a fantastic job done with attention to detail
Old 2nd December 2020, 05:21 PM
surely its got to be 2 different cars??
Amazing job as always
Old 2nd December 2020, 07:57 PM
Putting the interior back together pre-MoT. Its not a happy place in there as it has been very wet for some time, such that the terminals for the passenger footwell light just corroded away to nothing!
I had to cut quite a bit of wire back as it was corroded inside the insulation, so made up some repair wires from a scrap harness
Crimped in place and working again
Next job is to repair a few broken trim panels and then clean the mould off the dash and headlining so its a relatively pleasant place for the MoT tester to sit
ID:	24763   Click image for larger version
ID:	24764   Click image for larger version
Old 2nd December 2020, 09:24 PM
I can feel the love all the way from Devon!
Old 3rd December 2020, 10:46 AM
homer simpson's Avatar
Another amazing job! Just shows what can be done to a car in such a poor state - only by the right people (person) though! Well done MJ
Old 4th December 2020, 07:14 PM
The car passed it's MoT this afternoon
Last couple of jobs this morning - 1st was to clean the undertray because <puke>:
Much better!
One interesting point to note with the Febi upper arms is that they come with bolts for steel uprights, not aluminium ones. I think they basically used an A4 kit and swapped in the D2 front upper which is disappointing. Meyle therefore are still the only ones who supply the correct hardware.
This is the M10x105mm bolt for the steel uprights - not fully engaged with the nyloc nut. It did the job for holding everything together but is not acceptable to stay like that.
and this is the correct M10x110 bolt for the aluminium uprights (N 10491802):
Some final tidying tomorrow and a wheel alignment on Monday and then its done
ID:	24768   Click image for larger version
ID:	24769   Click image for larger version
ID:	24770   Click image for larger version
Old 4th December 2020, 09:44 PM
Joe2.0E Joe2.0E is offline
Remarkable attention to detail as always, it should fly through the MOT.
You might post some details on how to remove mould from the headlining or what cleaning product you’d recommend for such a task.
Thanks
Old 4th December 2020, 10:13 PM
That must be so satisfying and - as ever - I'm in awe, as I can't imagine achieving even 10% of what you do with these cars - in fact, I sometimes wonder if we're the same species
Old 5th December 2020, 09:33 AM
pete-p's Avatar
pete-p pete-p is offline
Excellent news and not unexpected really! Must give a good feeling of satisfaction though after all that work I'm sure
Cars...
Old 5th December 2020, 10:18 AM
RICKY D's Avatar
RICKY D RICKY D is offline
I just love reading through these build/rebuild threads by MJ....it’s like therapy for me
Top work as always MJ
2016 S5 Coupe Black Edition - Ibis White
