Old 22nd November 2013, 10:50 AM
I've got a 255/35/20 on a 9'' rim and tyre isn't stretched, it sits beautifully, and combined with lowered suspension it offers very very nice handling
So, I suspect a electronic fault as well, now it could be as simple as even loose connection or wiring issue on a abs sensor or possibly steering angle sensor.
Hard to say, but will have the car over the weekend.
Yesterday's test drive confused me completely for the first time, 2 hours drive with various tests and nothing until going over the bumpy rail track when all warning lights just came on straight away.
Old 22nd November 2013, 02:08 PM
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224B051DFD400F0EA27-8077
3 Faults Found:
00003 - Control Module
014 - Defective
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
ABS ECU says it's defective by itself. So that would probably be first on the list.
I believe on D3 this comes on ABS pump.
On lot of cars they fail because of dry solder joints. I have recently repaired one by cutting it open and re-soldering joints on Volvo.
Old 22nd November 2013, 03:56 PM
Hmmmm.....even if brakes and everything else is working fine ???
Old 22nd November 2013, 04:04 PM
...it kind of make sense, ignore last message.
Have you ever done it on D3 and did you re-solder all the joints or the ones which needed doing were clearly visible??
Cheers mate, very much appreciated
Old 22nd November 2013, 04:11 PM
....sorry, me again, did you do the actual reflow of the whole board??
Old 22nd November 2013, 04:18 PM
Never done on D3, just done it once on friends Volvo, his had failed and garage wanted silly money to replace pump with control unit so I gave it a go and it worked.
I just re-soldered the big joints that usually crack with regular soldering iron. The ones for plug, solenoid coils, FET's etc.
Old 22nd November 2013, 04:28 PM
OK...thanks for the tip mate.
It could actually make sense.
I even found by mistake a company in USA (they've got obviously much more A8s so the bigger market) and they were specialising in reflows/reballs of D3s ABS ECUs. It could probably be that the big joints were failing but they were making from it a much bigger job, re-soldering the whole board, just to charge more.
Their service was 300bucks.
Hmmmm.....
Old 22nd November 2013, 11:01 PM
I agree with ainarssems, it's a steering angle sensor error code, not a brake pedal sensor or ABS sensor error code. I think you need to do basic settings with VCDS. The instructions are probably on the rosstech site or ELSAWIN.
Old 25th November 2013, 07:42 PM
I haven't got any update for you guys, but help was and is still very much appreciated.
Instead of doing some work we've spend all the time on mastering the Carbon interior on my car....and then we've had a Jack.....so Sunday was a pretty rough day.
As soon I know anything I will update this page.
Once again Thank You guys.
