Old 31st August 2010, 03:15 PM
Default A8 with sport suspension: Looking for HIGHEST tyres to use with standard 18xJ8
Hi everyone,
I've got 2002 A8 on sport suspension with standard 18" J8 rims. Oh well, actually not completely standard. I've got these Audi original 18" J8 monoblock brushed aluminium rims:
Question: What is the maximum profile tyre I can put on these rims? I need maximum possible radius of the wheel. Don't care about width of the wheel. The reason I'm asking is because I'd want tyre to occupy as much of the wheel arch space as possible and I just love high profile tyres as the ride feels kind of softer on them.
Standard tyres are 245/45 R18. Does anyone use 245/50 R18 or 245/55 R18 or 250/45 R18 or 250/50 R18 or somehting like this? Please share your experince.
Thanks!
Old 31st August 2010, 03:41 PM
Now here's a first! Most peeps want ULP tyres on huge rims!
As long as you realise that if you increase the profile without reducing the width of tyre then you'll need to recalibrate your speedo there should be no reason that you can't put 245/55-18 tyres on the car.
You'll gain on MPG and loose on accelaration and handleing in the corners; but if your not a spirited B road driver you won't care.
You could of course lower the suspension and fit bigger tyres.
Please keep us informed of the results.
Old 31st August 2010, 05:22 PM
Thanks Conan,
Does it look like confirmation 245/55-18 should fit without rubbing? Great.
Also, could you please explain the logical connection between lowering of suspension and installing bigger (higher) tyres?
I always thought (excuse my ignorance) that lowering suspension kind of reduces space in the wheel arch, making risks of rubbing higher...
Am I wrong?
Currently I have sport suspension. Below are some pictures of how the actual car looks just if it helps to check my current level of lowering.
The rims I'm going to fit on this car are basically the same 18" 8J ET48, but of a different design:
Old 1st September 2010, 09:48 PM
Conan,
You mentioned "you'll need to recalibrate your speedo". Can this be accomplished by VAGCOM? I searched ELSA, but couldn't find how to recalibrate speedo. Can you please advice?
Old 2nd September 2010, 11:45 AM
I don't have ELSAwin at the moment but it is in there. Or was in the last copy I had. basically you mark up a fixed distance of 100Mtrs from your front tyre. Mark your tyres so you can tell how many rotations it makes over the fixed distance and then programme that into the car.
I won't be able to look on ELSA for a while as Win 7 won't run it!
Maybe someone else cal look.
As for lowering the suspension. Look at what mkoneman has done. by combining lowering the suspension and increasing the aspect ratio of your tyres you will fill the arches without going to the extreems that he has done. For a motorway cruiser this should make for a stable and very comfortable ribe. Just increasing your tyre aspect ration will lift the body higher off the road, reducing stability.
HtH
Old 2nd September 2010, 01:22 PM
Mike,
Go to the microsoft website and get XP mode for Win7. it's FOC and you essentially run a copy of XP in a window.
Old 2nd September 2010, 02:45 PM
I love it when you talk geek to me Richard!
Old 2nd September 2010, 09:48 PM
Nice colour, please post pictures when you have the new wheels on.
Old 3rd September 2010, 09:34 AM
Any details about recalibrating speedo are welcome, though I seriuosly doubt it's possible. Searched ELSA and Google. Google suggests it's not possible
I'll post pictures when ready. VAG community love to mount these rims (usually called "A8 L monoblocks") on smaller cars with ULP tyres. What I like about these wheels is the fact they are not painted. They are justed brushed and polished, so it's always possible to remove scratches with simple polishing procedure since there's no fear to damage paint. The shiny surface you see is bare aluminium alloy -- it's not chrome coating or a paint. I must say these wheels are very heavy as it's just a monoblock piece of forged aluminium. Not sure they are great for racing...
Here's another picture. Not sure what tyres are used though.
BTW, I've got Vista and ELSA works on Vista no problem. The important thing is to use "run as administrator" feature. And then to install Adobe SVG viewer to be able to see electrial wiring diagrams properly.
Old 14th April 2011, 12:54 PM
OK, managed to install these wheels after 7 months! My car has sport suspension. I've used 245/50 R18 tyres -- the highest you can use with this suspension. Wheels completely occupy arches, but don't rub. Rims have standard size and offset and I didn't use spacers. Tyres are ContiSportContact 3. I've chosen that model because it has widest "rim protection" from what I've seen.
ID:	1761   Click image for larger version
ID:	1762   Click image for larger version
ID:	1763   Click image for larger version
