Old 29th January 2021, 11:26 AM
What does that imply now?
Seems like you just need to turn the heating up.....
Old 29th January 2021, 11:54 AM
HPsauce HPsauce is online now
Thanks Mark, that's what I'm thinking too. I'll just wait until/if it gets worse then have a look.
I've found how to get inside, there are clips along the bottom edge that appear to just prise open then the back cover should just hinge off - after removing the stand first of course.
The stand is just a couple of screws; designed to come off easily as it also has VESA mounts on the back..
Old 5th February 2021, 12:58 PM
Ronin Ronin is offline
Since its just artifacts/pixels its definitely nowt a power supply or inverter fault, I would take it apart (usually you take off the front fascia off, its always press fit) and just have a general look around and reseat all the ribbon cables and look for blown/domed capacitors, those are cheap and easy to replace.
If you lived close I would happily have a look for free but we have covid and i live in Wales haha.
