Front Shock Absorbers FL D2 S8
Some advice please.
I am presently addressing some age old issues on my 2002 S8 and have gathered together some new components to fix MOT advisories (manifesting as a couple of front end creaks/groans). Following various extremely helpful posts on here I have successfully navigated the 20" wheel control arm part number maze but now have another issue. When I purchased the car some 5 years ago it came with a new spare pair of Audi OEM front shock absorbers (Pt no 4D0413031AQ), which I thought might now be worth fitting if I was accessing the front suspension. However after looking at a few part no listings, i think I now know why they may not have been fitted previously. They appear not to be applicable to the 2002 model year! So hence my question, is there any minor combination of other parts which would allow these SA's to be fitted to my car, eg different combination of spring or spring platforms or is the problem more fundamental? Many thanks, G
________________ Cars: 2002 D2 S8 Aqua (gone but not forgotten) 1988 UR quattro 2003 A2 FSi Sport 2020 Seat Leon Cupra R ST Abt 1989 911 Carrera Cab Couple of Mk1 Golf Gti's (in bits) |
I think you can change the whole strut with spring and spring cup from PF and FL and it's fine but if you just put PF shock keeping FL spring and cup on FL car you end up with lower front, I am sure MJ will know more.
PS. if anyone is interested I still have unused pair of PF S8 shocks but no longer have car.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 29th May 2020 at 08:26 AM. |
4D0413031AQ is for the PF 2.8 sport so will have quite a different weight profile to an FL S8. I would be disinclined to fit those to an S8 tbh as it may end up under-damped.
The best dampers currently available for the D2 are the Bilstein B6, but they are a tad spendy at 150 a corner. Very much worth it if you enjoy a 'spirited' drive from time to time though Ainars - I'm pretty sure you are correct there. I can't remember the exact differences tbh as I don't see many PFs so I'd need a set side by side to remind me. |
Just checked my unsused pair is also AQ, also checked original struts that I took off because of broken springs and they are AR.
Not sure how much weight difference is there between V6 and V8, I think engines are about same weight as V8 is aluminium block and V6 is cast iron. I am pretty sure seeing somewhere that 2.7 TT V6 is is heavier than V8 in B5 and C5 because of added weight of turbos and intercoolers so V6 without forced induction should be in the ballpark of V8 PF V6 would be only 2wd so some weight saving there but what's the total difference and how much different shocks would affect no idea. Had a look at Billstein catalogue for B6, it lists the same part number for front shocks 24-026093 for all versions of D2 I checked regardless of engine or 2WD, 4WD, PF or FL, sports or standard suspension
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 29th May 2020 at 10:13 AM. |
Yeah the aftermarket tend not to differentiate between models or specs at all, yet Audi have different springs for every equipment level, and almost as many dampers. The Bilsteins would give a stiffer ride on the V6 than the V8 because they are valved as a best-guess average.
The V8 is about 25Kg heavier than the V6 with accessories fitted (I weighed them), and there is about 50Kg difference between the 5HP24a and the 5HP19FL so three bags of sand different on the front axle. Thats a fair chunk of weight. |
