Old 2nd February 2014, 08:08 PM
johnny_quattro's Avatar
Unhappy Gearbox - limp home mode grrrrrr
Hello to all. My old girl is an A8L FL 2000 model, 4.2
Can anyone offer advice with regards to the A8 gearbox entering limp home mode? I was just outside of Gatwick and went to pull away at the roundabout. I heard an enormous thump and lost drive. Put my HWL on and then noticed all red lights ablaze on the dashboard (PRND432). I managed to pull away with about 2000 rpm (going nowhere fast) and managed to get back to a friend's house.
I noticed a couple of days ago a slight non-output of power when changing gear. MY gearbox has always thumped a bit when drawing up to a junction, I suspect when changing down from 2nd to 1st gear. Nothing since apart from today's experience.
First off, I'm going to try to get back home which is a 15 mile journey. Is there any danger in attempting this? Secondly, will a gearbox fluid change help in any way or am I going to be throwing money away? I say that, because I read something on Paul Waterloo's audipages.com site about something similar and the chap in question managed to fix his problem with a fulid change. That would be a right result compared to the cost of either a repair or reconditioned gearbox.
If a gearbox recon looks like the only option, does anyone have any recommendations for companies in the South London/Surrey area?
Thanks in advance for any insights or assistance.
Old 2nd February 2014, 08:15 PM
Hello John, really sorry to hear that. Presumably this is the car that's been off the road "in protective custody" for so long.
I guess the first thing to do is get VCDS plugged in and see what that reveals, but it doesn't sound good.
Based on various threads here there ought to be a viable business rebuilding these boxes as they do seem to be the "A8 killer" in many cases.
Old 2nd February 2014, 08:30 PM
If you value your car don't drive it. Put it on truck and bring it to ZF specialist. I can recommend Chester Transmissions. I predict it will be full gearbox rebuild.
Another option is finding the same model of used gearbox and finding someone to help you swap it.
Old 2nd February 2014, 10:49 PM
There are normally two specialists recommended on here, but neither are down south:
1 - Chester Transmissions - as mentioned (in Chester, unsurprisingly!)
2 - Mackies, in Glasgow.
I've used both. Chester did the gearbox flush, which made the problem much worse (a common result, from other's posts on here, and not their fault).
I then drove it (VERY carefully…) to Glasgow, where Mackie's rebuilt it, perfectly - but expensively. I chose Mackies over Chester due principally to the quality of their guarantee - 100k miles on the rebuild
Old 3rd February 2014, 05:28 AM
Default Codes 17114 and 17117
Got the car back home late last night, and ran it through on my cheap £20 reader which showed the two fault codes, 17114 and 17117. I'll probably go for a fluid change first to see what good that does, if any.
I'm going to try and investigate some more 'local' options first while the car is off the road for the time being. Thanks to everyone that chipped in, and I'll post back here if I have any news. Nothing is going to be happening on that front until Thursday, when my current shift ends.
Old 3rd February 2014, 06:30 AM
mannyo mannyo is offline
17114 is gear monitoring, incorrect gear ratio.
17117 is also incorrect ratio for 3rd gear.
Reading elsewhere the only cure maybe a transmission rebuild, choose the specialist wisely.
Manny
Past
Tags
gearbox limp home a8l fl
